Please check - if you have "Manual" option enabled, events will not run automatically. Also check the events if they are enabled and their start times are correct.
Sorry, there's no Manual option in RB Cloud, so the only thing you need to check is is the events are configured properly.
I checked your streaming account and the events are starting there - you can see it in the Logs section.
