the volume goes down after a few days
xzsaimon16
hello again, it is to report that after certain days around 5 maybe less or maybe more, the volume goes down by itself. the setting that does that is disabled. This problem has been going on for a long time and to fix it I have to restart the program. Is there any command that can be used to automatically restart only the radioboss?... I know there is a command that restarts the computer
I had this too, but it was not Radio boss as such did you perchance set a genre up and add it to your file type and set lower volume this did this to my lush music another reason is that you are using the track volume which is wrong. Personally, i don't like radio boss global change am sure it is fantastic in the right hands. in your miscellaneous playback settings, there is a lots of track gains. Can i also suggest you sav and back up setting in radio boss and reimport if it goes wrong. I hope this helps.
