assign advertising position
excellent.
Surprised by the versatility of "RB"
I just found a way to do it.
The only problem I see at the moment is the trading block update.
if a "PGP" list is executed, there is no way to immediately update the business block it contains.
In that aspect I think a "command" would be the most appropriate.
For example:
rock music block
sweeper Radio
rock music block
Jingle radio.
rock music block
runadvertising.command=30 (advertising block)
metal music block
Jingle radio
metal music block
sweeper radio
metal music block
The idea is to be able to update the trading block at any time.
If we manage to do this, it will be possible to update the trading block before it starts.
WITH THIS COMMAND UPDATE THE BLOCKS...adsupdate
hello Paulo.
How should I do it, I try but it doesn't work for me.
in fact try doing the following:
remember that I need to update from "PGP".
In this case you need to create playlist again, it will take into account updated ads playlists.
I don't think a new command is needed because it's already doable with existing features.
There is no way to update when you are already inside the playlist.
Let me explain if I run a "PGP" list of one hour duration and within it I have 2 trading blocks, the system does not allow me to update them instantly.
It is doable but it can be improved.
it is necessary to be able to update a trading block at any time.
we should not wait for the next event for the ad units to be updated.
You should update ads playlists first, then generate music playlist that will insert already updated ads playlists.
You can schedule adsupdate events more often. It won't hurt.
That's right, that would be the closest solution.
what would be the correct way to do it?
The idea would be to update the commercial block, which is inside "PGP".
I have the following problems with the playlist.
I'm adding a full listing during certain hours and can't adjust the ad times.
How could I better calculate times?
Is it possible to delete comments as the playlist progresses?
You should run the ads using the scheduler, this way they will start when needed.
I already did it this way, but unfortunately it destroys the structure of the previous event.
and even if you queue the event, the timings still fail.
I think a more practical solution would be to create a smart list, where events have set times.
while music, jingles, etc. They remain in the background but without losing the structure.
This is a known issue, and will be fixed in one of the next update.
excellent.
Looks like you should use the "Overlay playback" option: https://manual.djsoft.net/radioboss/en/eventoptions2.htm
