Excellent Broadcast Compressor
A free VST plugin: JB Broadcast.
Very low resources.
It was already mentioned in another topic - http://www.djsoft.net/smf/index.php/topic,3480.msg16491.html#msg16491 - looks like a useful piece. I think we'll add it to RadioBOSS download page.
I have a question. Why when you install JB Broadcast in radioboss it lacks the presets option at the top of the plugin interface? (such as in this attached picture) Or am I installing wrong version?
RadioBOSS doesn't cut any parts of the UI, looks like there are different versions of the plugin, and some of them do not have the plugin selection feature.
Maybe, but in most plugins, the presets are generally something that the VST Host can extract. They are displayed in the DAW or host of choice, as part of that UI.
For example, when running broadcast in reaper, the presets are not displayed in the window generated if the plugin is running as a separate process. The window containing broadcast just has the parameters.
AFAIK there's no standard preset API for VST plugins, it only allows listing the parameters and get/set its values. If the plugin itself has plugins, it can be used, e.g. StereoTool has it and it works in RadioBOSS.
I have never seen the JB Broadcaster where you have these settings at the top
Where can I get this JB Broadcaster?
