mac version of radioboss
Was this idea completely given up on?
I'm about to have a new macbook, but the only one in my budget is the m1 macbook air with 8 gb ram. I know I can set up a Windows VM on it, through either VMWare or UTM, but for a virtual machine, they always say use half the cores and half the ram for the virtual machine, and that worries me. Not sure how stable a vm with Windows 11, Radioboss, plus a screen reader will be with only 4 gb of ram. It would be much better to have a version of Radioboss that would run on Mac OS, or if you can't do that, give us a way to have a browser based studio of sorts with RB Cloud.
For now there are no immediate plans to create a Mac version.
RadioBOSS doesn't need a lot of cores, so I'm pretty sure it'll work fine in the VM.
The only web-based solution is RadioBOSS Cloud.
