Lyrics
patrick.de-bruyn
I was asked in my Facebook group if it would be possible to send song lyrics as well,
for example as title format %lyrics in the global metadata
do i understand correctly that the lyrics have to be included in the MP3 tag ?
If so, which program could I use to add or edit them?
Yes, lyrics must present there. Any software that specializes on editing tags should be able to handle it, e.g. mp3tag.
The LYRICS metadata included in the file contains all the lyrics in a timeless manner, and sending all the lyrics as information may cause errors in some applications, for example, in the MPC application. Instead of this metadata, an option can be provided to show the current lyrics with a timestamp. filename.lrc
