Problem with the microphone Radioboss
Meesmaalt
I added a microphone to my computer via USB. The microphone works fine under the computer's enhancements. Pressing MIC in the Radioboss program turns the sound down but I can't hear myself talking. Why ?
What RadioBOSS version do you use?
I got the problem solved. The mistake was that I had disabled the microphone for the radioboss program from somewhere else.
Where do you enebled your micro? I have the same Problem. Can't connect my micro and/or a line input.
OLA EU USEI A WEB RADIO BOSS POR 3 ANOS SEM DAR PROBLEMAS 2025 SUMIU O MAPA ONDE VISUALIZAVA OS LUGARES QUE ESTAVA OUVINDO ,O CRIADOR DA MINHA PRIMEIRA WEB RADIO TEVE AVC NO FINAL DE 2024 FIQUEI SEM SUPORTE E COM ISSO ME INDICARAO UM MAIS ATE SEXTA FEIRA DIA 20 FIQUEI COM O SERVIÇOS DELE POREM ELE NAO ME DAVA SUPORTE ENTAO VOLTEI COM A PRIMEIRA WEB RADIO MAIS ESTOU TENDO PROBLEMAS COM MICROFONE ESTA TUDO CERTO NO MEU NOTEBOOK MAIS JA TEM UMS 10 DIA QUE NAO CONSIGO FALAR ELE É USB E O MOÇO QUE ME DAVA SUPORTE ELE DISSE QUE SEM MESA NAO FUNCIONA MESMO ,MAIS DE 2022 ATÉ 2026 USEI SEM MESA DE SOM TERIA COMO ME AJUDAREM
