song request and website song list integration
Hi, here is the script I developed for my radio Made in 80.Just upload the 3 files to a web host and modify the settings with your information in the request.php and request_submit.php file
  • RadioBoss_Request_Song.zip
I made a script for my radio (see screenshot) if that's what you want to do? I can share it with you for free and help you set it up. I will need some information about your radio to customize it with your settings. Contact me.
Dear friend, I thank you for the help. My radio is called "HD Radio". I appreciate your kindness, don't worry, I change the script data, sharing it for me is more than enough and kind of you...
Hi, I was trying the script and I get this error. "Erreur lors de la récupération du contenu XML." Greetings
