radiocaster error
diabolix
radiocaster has an error, when going from input line to capture, it gives an error, it didn't do it before, please check it, for it to work you have to close it and open it again and it is a hassle, thank you
Can you please specify what does the error message say? And what RadioCaster version you have?
YES, I use 3.4.0.0 although due to the error I had gone back to the previous one and even to 3.0.0.0 and now it does it with everything and I get this error when changing cards, (note that I said that I didn't do it before)
message is : Device init error: No description (-1) (code=1). plese check setting
I have the same alert on my version 3.4.0.0: a window that displays an error. But no indication... I saved the report if necessary. Should I send it to you?
Yes, if you may, it will help in improving the software.
Since my last message, I have had an error message which has been appearing regularly for around 15 days and almost every day (See attachment : Error E06D7363). I can't save the error report which freezes.
The problem is recurring and causes broadcasting to stop: it’s problematic.
I note that the problem occurs more frequently since the last Windows 11 update.
I actually have a third-party DSP plugin that I use for sound processing.
FYI, I disabled the screen lock on Windows 11 for 4 days. I no longer have any cutting problems. And I will try to send you an error report if it happens again.
It keeps giving an error, it's not the dsp, I disabled them and it keeps happening but one thing I have noticed, as audio input in wasapi there is no problem when changing to direct sound it gives a problem I think the problem is with the card controller, I think the problem would be solved if the wasapi controller was also put in sound capture
