How to program to place a separator before the requested song, but have the separator sound only when there is a requested song
cheodj
Greetings I need to ask a question I am receiving song requests but I want to place an event where every 6 minutes the requested song is placed Everything works perfectly What is my concern I want to place a separator that says this song You requested it and here it is and it starts the song that was requested. I did it well by programming events with multiple options, I placed the separator and then the command to see if there is a song and place it. but it happens that if the song has not been requested within the next 6 minutes, only the separator plays. There is no way to schedule the request for a song but not for minutes in the event scheduler but rather when he has a request for a song he immediately places it in the queue of the list for it to be played so he can identify himself. with the separator and play the requested song. I don't know if I can explain myself, I hope you understand me, I am delighted with Radio Voz. I have several ideas that I am going to pass through this forum so that they can integrate them, but it is a very pleasant system to work on radio and with some things that it lacks to be able to work. on visual radio in advance, thank you. I look forward to a quick response.
The trick I used was to create a separate secondary music library where I imported all my songs. I then tagged them all as "Requests", and assigned an to Auto Intro to all songs in that tag category (Requests). So anytime any song from that category appears on the Playlist through a request prompt, it'll automatically play the request sweepers first via auto intro.
Thanks, I'll try it and let you know.
I did what you told me but when I tag requested in the new database and it tags me in the original too...
Could it be that I'm not doing it right, when you say create another library, how do you do it because I create an example musica2 and then import from this menu, add and then import from musica1, is that right?
I found myself having to duplicate my music database into a separate folder and then imported those duplicated files into the library and then tagged them all as 'Request'. So my music files in the original library retained their original tags and their duplicates in the new library I tagged as 'Request'. I found this to be the easiest way for me. This way I could specifically assign an auto intro only for songs that were in the request library without interfering with my standard library.
I found myself having to duplicate my music database into a separate folder and then imported those duplicated files into the library and then tagged them all as 'Request'. ... If you could tell me how to do it because I tried to do it in a different folder but it doesn't recognize it.
Yes, this is a problem, in one of the future updates, we'll add conditional statements to the scheduler that will allow skipping intros in such cases.
Thank you, it would be interesting if you applied it, something that would be good if you applied it to new updates is that just as you can program the start date and end date of a song from the library, they will also add the time period, since in my country there are songs that can only be played by law at certain times. thank you
This is possible in the track properties, if you set start and end dates, it will affect Playlist Generator and Track List (they will skip the tracks outside their allowed dates).
Yes, I know that the date can be programmed but not the hours. If I explain myself, it would be good in the future to add the time, for example... from January 15 from 9:00 p.m. to January 30 until 5:00 a.m.
If you use the Playlist Generator, you can add Tags https://manual.djsoft.net/radioboss/en/using-tags.htm and configure filters for the categories. Tags can be for specific hours, or more broad like Day, Night etc.
