Deleting Tracks from Folder Automatically
VBRadio
Hi,
I'm aware of the 'delete after playing' option in Playlists for RadioBoss cloud but I wonder is there any way for a track to be removed from it's enclosing folder on the server?
Scenario: I have 500 tracks that play randomly in a playlist triggered by an event. I would like each track to be removed totally once played so that eventually the folder is empty and I can replace with a totally different 500 tracks.
Reasoning: I don't seem to have much success with the track protection settings and hear records more often that I'd like... even if this is once every few days.
Thank You in advance for your time.
It does not have capability to delete the files.
Deleting the files and then re-uploading them seems to be a complicated way to achieve repeat protection, I think you should adjust the repeat protection rules. 500 tracks and some tracks repeating every few days - seems reasonable.
