RadioBOSS 7.1 [beta]
Yes, we noticed If you have an ative playlist and it has inerted voice playlist after the current song and you get to another playlist window open, right-click and 'Add tp Playlist Que' or press Q, it does not play the inserted playlist and leaves it in the previous playlist. Hope this helps.
If you add the queue, it will have priority and will play the queue, not what was inserted before.
Hi,
I have a bug with this version when playing an autointro, the volume goes down at the end of the autointro and it doesn't go back up.
The song is with a low volume until the next one.
Any idea?
Good morning, no settings have been changed. (Error while resizing the current track artwork)
Test:
10:37:05;error;"Error while resizing the current track artwork.";
10:37:07;;"Dire Straits - Sultans of Swing";"E:\TUTTO_ROCK\DIRE STRAITS\The Very Best Of Dire Straits\01 - Sultans of Swing.flac"
10:37:07;error;"Error while resizing the current track artwork.";
10:37:10;playback;Stop;
10:37:10;error;"Error while resizing the current track artwork.";
How does the command look like, do you use run PlaylistGeneratorPro.exe ... ? Are there any error messages?
No, in fact the command worked before as is.
run PlaylistGeneratorPro.exe "-preset=PAR" "-out=D:\PARA RADIO\Data Base Radio boss\PLAYLIST\PAR.m3u8"
Maybe it appears, but closes immediately for some reason.
According to the task manager, clicking the programmer's manual button activates the "Antimalware Service Executable" service/process.
It is the only "considerable" process that is activated at the time I try to activate the command.
PD: I have disabled the antivirus but now the process does not appear. but it still doesn't work
Currently it's Time Stretch feature and Remote Voice Tracking. Most of the new big features in the future will also be added to Ultimate only.
Time Stretch not work in the demo version?
It does skip all the file types, stretching is only applied for music. The adjustments are visible in the # column like "1. [+3.4%]".
because I don't see this in the column, nor does it seem to modify the pitch when I activate it
Thank you, will be fixed.
Do you mean in the ads list show what's wrong with a block?
In RadioBOSS click Settings, Open Settings Folder, then open Logs and the log is in ads_export_log.txt file.
Currently only buy an upgrade from your current edition (during the beta it's 50% off) or apply for a beta tester key.
Here are the 3 situations:
There are more minutes than established for the block
There are more ads in the block than established
Both situations
I set a Container Name in the ads scheduler settings, but I can't see that name anywhere...
Where is it shown?
It doesn't show up in the playlist
It doesn't appear in the logs ...
Also Have noted when using shuffle if a voice scheduler even is placed into the active playlist on finishing the schedular even it plays the next song in the playlist not a shuffled one if its enabled, hope this helps.
does that mean we have to pay to test this ultimate version wenn using our own Key?
And Anyone who contributed will get a significant discount, up to 100%, when the final version is released. would also only be for the advanced version
that doesn't really feel fair to me
Yes but it inserted intro via playlist but avoided it qith a re Q I was just was mentioning it in case you were not aware
I would like to have a function to locally mute the cartwall buttons individually without affecting the volume on the stream
Just like you can mute the microphone locally
yes i am talking about cart tracks voice tracks in auto intro the volumes have all changed i found something in preferences too
I would like to know how voice track margin works. What does it do? Is it to determine how much time elapses until the next item plays? I've tried it. It's not working.
