RadioBOSS 7.1 [beta]
yes i am talking about cart tracks voice tracks in auto intro the volumes have all changed i found something in preferences too
there is nothing new in thath section, its the same as in 7.0.8 version
When updating the library automatically, it can assign specified Tags for the newly added tracks
The challenge I'm finding with this so far is that sometimes the new tracks might require different unique tags. From what I've seen, this feature forces you to select one tag that will be applied to all newly added tracks.
A preferable option would be, especially for us who use a folder based system to manage our music database, to make it so that a tag can be assigned to a folder location so that whatever new files are added to that folder are automatically assigned the relevant tag for it, and the same for all the other music files newly added to other music folders.
Scheduler: added a command to render playlist to a file (renderplaylist)
Would it be possible to share a tutorial showing how this can be done in practice. For example if you want to generate a playlist and immediately render it and have it saved to file in a specific location.
Or perhaps allow for multiple (separate) update library instances so that for each instance we may target a specific folder to which we can assign (a) default tag(s).
RB Beta locking up when it plays a Schedule voice track
I tried to upload DMP file but it was to big for the forum as you can see it locked up at this point halfway playing the mp3 intro it had done before Presumable radioboss_gaurd is not working? As it entirely lock up RB which has to be closed from the Task Manger in Windows 11.
What's new
  • Introduced new RadioBOSS Ultimate edition. RadioBOSS Express edition is deprecated.
  • RTMP streaming support
  • Remote Voice Tracking module (Ultimate edition only)
  • Time Stretch feature: change playback speed of the tracks to make end at hour end (Ultimate edition only)
  • Remote control API: possibility to create users with limited rights
  • Style option: scale the secondary windows by set percentage
  • Nowplaying bar size option: Large (menu View->Top panel->Large)
  • Track List presets for repeat protection rules (Track List entries can now have different repeat protection rules)
  • Global hot keys added (menu: Settings->Hot Keys)
  • New tab type: Log
  • Containers in the playlist can be named
  • UAC: certain cart walls can be unlocked to
  • File type identifier for containers (container=)
  • File types: default artwork option
  • Logs: add track titles to the log when a network stream is playing
  • Sweepers: option to combine multiple sweepers
  • Sweepers: specify minimum duration to sweep
  • Scheduler: override artwork for streaming and export for scheduled items
  • Scheduler: added a command to render playlist to a file (renderplaylist)
  • Auto Intro: added "Cooldown" option for the rules to prevent a rule from being used too often
  • Auto Intro: added separate fading settings for Auto Intro (previously used settings for voice tracks)
  • Auto Intro rules based on file path
  • Track List: a music library can be used as a source
  • New playlist columns: Event name, Event waiting, Segue Editor, Track Tool, Voiceover, Mix
  • Waveform drawing improved (better precision) for Track List and Segue Editor
  • getfile command: added option to select files in order (alphabetically sorted)
  • Scheduler: added "Expires" column in the scheduled events list
  • Log: filter entries by file type
  • Search: added Language field
  • Text to Speech: %hp variable for 12-hour clock
  • Voice Tracking: separate fade in/fade out settings for the underlying music
  • Voice Tracking: default Intro and Outro values for tracks with no intro/outro set
  • Voice Tracking: recordings are now saved in FLAC format instead of WAV
  • Broadcasting title can be added for Teaser items
  • %filetype variable for HTTP requests
  • Advanced option: prevent clipping when using EBUR128 normalization
  • Advanced options: Fade In and Fade Out for voice track bed
  • Logarithmic/linear volume option now also applied for the AUX players
  • Removed ANSI encoding from HTTP notification settings
  • Reduced rate of error notifications when there are too many errors
  • Added "songrequestclear [age]" scheduler command
Ads Scheduler
  • Bulk edit ads in the list
  • Added new options for the generated scheduled events (name container, start event earlier)
  • Added warning: when a number of ads in a block exceeds certain value
  • Export process is logged to a file
Playlist Generator
  • Constraints: specify rules, which tracks can follow which tracks
  • Repeat protection rules based on Tags
  • Option to detect track remixes for repeat protection
  • Command line option to specify the number of playlists to create for each preset
Music Library
  • When updating the library automatically, it can assign specified Tags for the newly added tracks (makelibrary command also extended to add tags)
  • Added Cue In/Cue Out/Mix columns
Segue Editor
  • Improved precision for defined track and mixing positions
Fixed
  • Fixed: rendering playlist to a file didn't work properly with voice tracks
  • Fixed: repeat protection rules were not checked when rendering playlist to a file
  • Fixed: grid preset list was not updated sometimes in the Ads Scheduler
  • Fixed: streaming title was not sent from the Overlay players sometimes
  • Fixed Playback Queue bug when one track was added to the queue multiple times
  • Fixed: processed tracks counted in the Music Library sometimes was incorrect
  • Fixed TTS macro processing for overlay playback
  • Fixed: Playlist Generator sometimes did not take into account clock adjust option in RadioBOSS
  • Other minor fixes and improvements
License key
The free key expires May 15, 2025.
RadioBOSS 7.1 beta
x86 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.0.exe (2/8/2024, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.0_x64.exe (2/8/2024, 38MB)
Utility to remotely add voice tracks and edit playlist
https://dl.djsoft.net/beta/RemoteVT_setup_1.0.0.0.exe (2/8/2024, 6MB)
RadioBOSS Ultimate
Upgrade to RadioBOSS Ultimate from your current edition at half the price during the beta, click the appropriate link:
RadioBOSS Express to Ultimate
RadioBOSS Standard to Ultimate
RadioBOSS Advanced to Ultimate
In settings/hotkeys, the last 4 fields have no accessible labels. There are also no assignments by default, and no discernible way to es make global hotkeys.
This feature works great, and as intended. Which is so awesome. However, there may be a need to be able to include or exclude particular file types for this feature.
It is ideally best suited to apply to music tracks, but it appears that when a voice track comes after a jingle, commercial, news or sweeper, the default outro setting will apply to it too and the voicetrack will be triggered to play automatically. This is what is happening to me. I set my default outro to ten seconds, and now my voice tracks sometimes also play over commercials and sweepers instead of just over the end of a song.
I think the option to exclude file types for the default outro setting would solve this problem.
Hello.
I get the error "Error while resizing the current track artwork". The artwork for the currently playing song is not created, but the artwork for the next song is.
Cheers
I have a bug with this version when playing an autointro, the volume goes down at the end of the autointro and it doesn't go back up.
The song is with a low volume until the next one.
Does it happen with all the auto intros, or it's random?
Good morning, no settings have been changed. (Error while resizing the current track artwork)
Does the track has an artwork? If possible, please send one of those tracks to support@djsoft.net
Question - where is this setting located?
Settings, General, press "Advanced configuration" button, the settings are "Voice tracking - Bed fade in" (fade out).
No, in fact the command worked before as is.
run PlaylistGeneratorPro.exe "-preset=PAR" "-out=D:\PARA RADIO\Data Base Radio boss\PLAYLIST\PAR.m3u8"
Looks like there's a bug, will be fixed in the next update.
Time Stretch not work in the demo version?
If you see "RadioBOSS Ultimate" in the title bar, then it will work. The speed change will not be applied in case it's not possible to achieve the needed resilt. For instance, you have configured min/max speed change to +-5%, and required speed change to make the music end at the hour end is 7% - it will do nothing in this case.
Here are the 3 situations:
There are more minutes than established for the block
There are more ads in the block than established
Both situations
OK, it will show the warning reason, thank you for the suggestion.
I set a Container Name in the ads scheduler settings, but I can't see that name anywhere...
Where is it shown?
It doesn't show up in the playlist
It doesn't appear in the logs ...
It's shown in the playlist, in the Track Title column.
Also Have noted when using shuffle if a voice scheduler even is placed into the active playlist on finishing the schedular even it plays the next song in the playlist not a shuffled one if its enabled, hope this helps.
This is by design, the scheduled events have priority over the shuffle playback order. Otherwise, scheduled events would not start.
does that mean we have to pay to test this ultimate version wenn using our own Key?
And Anyone who contributed will get a significant discount, up to 100%, when the final version is released. would also only be for the advanced version
that doesn't really feel fair to me
To make it fair, we offer a 50% off discount for beta testers. After it's released, the discount will no longer be available.
Yes but it inserted intro via playlist but avoided it qith a re Q I was just was mentioning it in case you were not aware
Can you please post a screenshot to illustrate the problem?
I would like to have a function to locally mute the cartwall buttons individually without affecting the volume on the stream
Just like you can mute the microphone locally
Can you please provide a use case for it?
Patrick i think the silent vocals maybe this new settings Voice Tracking under cog. What is 'Voice track Margin'?
Voice Track margin controls when a voice track will end. Margin = 0 means it will end on the following track's Intro point, with a margin of 1 second, it will end 1 second before track's Intro.
I am trying to turn voice tracking off as i think its done this. As none of the voices should go through DSP
For the voice tracks, you can create a file type and check "Do not apply DSP" option for it: https://manual.djsoft.net/radioboss/en/using_different_types_of_files.htm (also check the "Treat as a voice track" option).
I would like to know how voice track margin works. What does it do? Is it to determine how much time elapses until the next item plays? I've tried it. It's not working.
You can have multiple "makelibrary" commands, each processing its own folder, and assigning a different set of tags. It can add tracks to some temporary libraries, the point is that the tracks will be processed, and those changes (added tags, any processing done) will be saved for all libraries, playlists etc.
An updated user manual will be released in the next update, with details on those new features.
Its absolutly AutoIntro its getting messed with I have my Intros at the end of song
Can you please provide some details on this?
It is allowed. You can have as many processes as you need. It's a good idea to not run all of them at the same time though as they are pretty CPU and drive intensive.
Please wait for it (about 30-60 seconds) to show a "Frozen" error message, then send a bug report - it will be a small text file.
Thank you, we'll check what could be wrong there.
Makes sense, thank you, an option will be added to exclude the file types.
I am testing the remote voice tracking and notice that the issue of voice tracks not starting at the outro point is still present. Have you worked on this point?
Voice tracks are positioned so they will end at the following track's Intro. Maybe in the future we'll add an option to start them at Outro point, but its not for this version, I'm sorry.
Thank you. On second thought, since for most people the default outro is going to mostly be used for music tracks, probably better to be able to select the file types to include, rather than exclude. Since we are likely to exclude almost all other file types besides music anyway.
There is a bug, or I don't know if it should work like that. I set a color for the background of a "File Type" (dark blue color). But when reproduced it still has the same color. I have activated the option to mark the played files (with dark gray). This only happens with the background set by the user. Since the text does work as it should.
Yes, that's how it should work. I suggest an option to alternate between how it should be displayed
Hi again
When you run a Remote Ads Update, the container name does not go anywhere, if you do it Local, it works fine
