RadioBOSS 7.1 [beta]
If you have repeat protection rules they will handle this situation. E.g. do not repeat track every 20 minutes should be enough.
In fact, in the rule you indicate, what I explained to you is generated "do not repeat track"
It would also be very useful to have permissions to block "add tracklist" from the menu as well as from the playlist in "edit item/rename file".
so that the programmer has more control over the work he is doing and no one can change the settings.
Hello, do you know where to find this options?
Time Stretch Feature: Change Playback Speed of the Tracks to make ends (Ultimate Edition Only)
thx for your responce
In this case "sweep time" appears to be large, as it'll have to replace the last track almost entirely. This option is supposed to handle cases like when the last track of the hour ends like 3 seconds before hour end, it will not try to "sweep" those 3 seconds.
In your case looks like you should add more sweepers to select from.
I just added my entire music collection as sweepers. The problem is not that a track, or multiple tracks, are inserted, the problem is that the "minimum time" setting changes absolutely nothing about the behavior of the scheduler. If I set the minimum time to 30 seconds, and the playlist ends 20 seconds after the start time of an event, tracks are still inserted. Like I said, I'm OK with tracks being added in order to get better timing.
That having been said, if the intention of the minimum time option is to allow an event to run early, that's also welcome. This way if a song ends a few seconds before an event, radioboss doesn't have to try to find something that may only be a few seconds long.
Hello There
Does it work properly with this option?
This seems a very specific permission, why disable only Track List? If they are allowed to edit the playlist, they are supposed to be able to add any items there.
It's in the Tools menu.
We'll check it.
Yes it works, but when you set it to random it generates what I indicated above.
We need to separate, one is the playlist where we add all the items, but the other is the “track list” where we configure the way we want the music to play.
It is necessary to have the ability to disable or hide this option so that no one can change the settings that have been made.
Personally, "track list" and "PGP" are options for the programmer, not for a basic user.
It would also be nice to be able to hide this:
I also see it as information for the programmer.
Other options that would be very useful would be to be able to insert a preconfigured pause in the playlist.
The following options are great for improving and speeding up your work.
We would need to add the pause, which can be used in thousands of ways.
i do this with a button in the cartwall you can click there (The fade out the music is set in the advanced configuration)
or with a button pause #20 and drag it in the playlist
Set arwork doesn't work properly. The cover is kept for a certain event, but only that. If you want to put the previous one or the rest in another event, it disappears.
Can you please provide more information about it? When repeat protection rules are enabled, there will be no repeats.
What rights will user with "playlist editor" permission will have? If they can edit the playlist, they will still be able to indirectly modify Track Lists, even if they don't have the permission, e.g. they can insert tracks from the playlist with their own Track List and then delete original Track List item.
What I mean is that "Edit playlist" permission is very powerful and allows to do many things.
What duration this pause will have? We can add a keyboard shortcut for Playlist->Add timed pause command, will this help?
I have already published the information and behavior.
If it is not possible to add a specific permission for the "track list", it would be nice to have the option to hide the option, to protect the settings made.
The duration of the pause should be configurable according to each need.
It's also a good idea to add a keyboard shortcut, I personally think it's more convenient from the playlist.
Both alternatives can also be added.
It has happened to me a couple of times.
Both categories have a restriction so that 2 "SALSAS" cannot be placed in a row.
That is a bummer. I bought the upgrade and now it says RadioBoss Express and I can't broadcast. Since update-subscription/upgrade license keys are identical this means I am forced to install a probably bugged beta 7.1?
AutoIntro Cooldown: Can someone please explain what this really does, when I set it to f.e. 20 % while the probabilty is 40 %?
now bugged, it was perfectly fine before ... it went on/off for several times before connection was stable again.
What's new
  • Introduced new RadioBOSS Ultimate edition. RadioBOSS Express edition is deprecated.
  • RTMP streaming support
  • Remote Voice Tracking module (Ultimate edition only)
  • Time Stretch feature: change playback speed of the tracks to make end at hour end (Ultimate edition only)
  • Remote control API: possibility to create users with limited rights
  • Style option: scale the secondary windows by set percentage
  • Nowplaying bar size option: Large (menu View->Top panel->Large)
  • Track List presets for repeat protection rules (Track List entries can now have different repeat protection rules)
  • Global hot keys added (menu: Settings->Hot Keys)
  • New tab type: Log
  • Containers in the playlist can be named
  • UAC: certain cart walls can be unlocked to
  • File type identifier for containers (container=)
  • File types: default artwork option
  • Logs: add track titles to the log when a network stream is playing
  • Sweepers: option to combine multiple sweepers
  • Sweepers: specify minimum duration to sweep
  • Scheduler: override artwork for streaming and export for scheduled items
  • Scheduler: added a command to render playlist to a file (renderplaylist)
  • Auto Intro: added "Cooldown" option for the rules to prevent a rule from being used too often
  • Auto Intro: added separate fading settings for Auto Intro (previously used settings for voice tracks)
  • Auto Intro rules based on file path
  • Track List: a music library can be used as a source
  • New playlist columns: Event name, Event waiting, Segue Editor, Track Tool, Voiceover, Mix
  • Waveform drawing improved (better precision) for Track List and Segue Editor
  • getfile command: added option to select files in order (alphabetically sorted)
  • Scheduler: added "Expires" column in the scheduled events list
  • Log: filter entries by file type
  • Search: added Language field
  • Text to Speech: %hp variable for 12-hour clock
  • Voice Tracking: separate fade in/fade out settings for the underlying music
  • Voice Tracking: default Intro and Outro values for tracks with no intro/outro set
  • Voice Tracking: recordings are now saved in FLAC format instead of WAV
  • Broadcasting title can be added for Teaser items
  • %filetype variable for HTTP requests
  • Advanced option: prevent clipping when using EBUR128 normalization
  • Advanced options: Fade In and Fade Out for voice track bed
  • Logarithmic/linear volume option now also applied for the AUX players
  • Removed ANSI encoding from HTTP notification settings
  • Reduced rate of error notifications when there are too many errors
  • Added "songrequestclear [age]" scheduler command
Ads Scheduler
  • Bulk edit ads in the list
  • Added new options for the generated scheduled events (name container, start event earlier)
  • Added warning: when a number of ads in a block exceeds certain value
  • Export process is logged to a file
Playlist Generator
  • Constraints: specify rules, which tracks can follow which tracks
  • Repeat protection rules based on Tags
  • Option to detect track remixes for repeat protection
  • Command line option to specify the number of playlists to create for each preset
Music Library
  • When updating the library automatically, it can assign specified Tags for the newly added tracks (makelibrary command also extended to add tags)
  • Added Cue In/Cue Out/Mix columns
Segue Editor
  • Improved precision for defined track and mixing positions
Fixed
  • Fixed: rendering playlist to a file didn't work properly with voice tracks
  • Fixed: repeat protection rules were not checked when rendering playlist to a file
  • Fixed: grid preset list was not updated sometimes in the Ads Scheduler
  • Fixed: streaming title was not sent from the Overlay players sometimes
  • Fixed Playback Queue bug when one track was added to the queue multiple times
  • Fixed: processed tracks counted in the Music Library sometimes was incorrect
  • Fixed TTS macro processing for overlay playback
  • Fixed: Playlist Generator sometimes did not take into account clock adjust option in RadioBOSS
  • Other minor fixes and improvements
License key
The free key expires May 15, 2025.
RadioBOSS 7.1 beta
x86 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.2.exe (2/14/2025, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.2_x64.exe (2/14/2025, 38MB)
Utility to remotely add voice tracks and edit playlist
https://dl.djsoft.net/beta/RemoteVT_setup_1.0.0.1.exe (2/11/2025, 7MB)
RadioBOSS Ultimate
Upgrade to RadioBOSS Ultimate from your current edition at half the price during the beta, click the appropriate link:
RadioBOSS Express to Ultimate
RadioBOSS Standard to Ultimate
RadioBOSS Advanced to Ultimate
Hello sir,
Please check the advert preset after setting preset then you can not delete it.
I'm not sure I understand what's wrong there. When you use a folder (or any other) source it will select the tracks based on selection type (random/in order) and respect all the defined rules (repeat protection, constraints, filters, etc).
There are two options: Playlist -> Add track list, that's for adding new Track List items, and right-click, Tools -> Edit, which will edit a playlist item, calling the appropriate editor, based on the item's type.
I added this for the future improvements list.
I suggest checking the rules and categories. Maybe some categories have repeat protection rules disabled, or this track came from the scheduled event.
With the RadioBOSS Ultimate key, only 7.1 and newer versions should be used. Previous versions will not handle the newer keys properly. There are no critical open bugs for 7.1, most of the bugs are in the new features, so you can use 7.1 safely I guess.
It's set in seconds. It means that when this Auto Intro rules is used, it will not be used again for the specified amount of seconds.
How can I install a proper working RadioBoss Standard version like it was before? This is insane!
The only way is to downgrade your key temporarily to Standard. Or just use 7.1. We'll be releasing another update soon with almost all reported bugs fixed.
Looks like it was something on the server. There are no bugs in handling those commands or streaming to the server.
Thank you, this bug is confirmed.
