RadioBOSS 7.1 [beta]
It's set in seconds. It means that when this Auto Intro rules is used, it will not be used again for the specified amount of seconds.
This is good, thank you. It was always problematic that sometimes the rule (even when it is set on 40 %) was used 3-4 times in an hour, and sometimes just once or nothing at all. So I guess when I set it to 1800 seconds (30 minutes) I can prevent AutoIntro being used too often / too short after previous one.
When I set it to 1800 seconds (30 minutes) maybe I can prevent AutoIntro being used too often.
Yes, it's also to handle the case when you have two or more rules that can be used, but it always/more often chooses one of them, this Cooldown option will allow using the rules more evenly.
Ok, but there is unfortunately still no way to set that in one rule (tracks with tag "new") it should choose the files in the folder in order instead of randomly. Maybe that would be easier.
So I guess the solution is to make seperate (same) rules in combination with cooldown.
This happens sometimes. On average, every 6-8 times.
Constraints is an interesting feature for me. Maybe add Years as well? That way, I can set a rule so that two songs from the same year don’t appear together, or after a song from 1980, the next one can’t be older than 1975, etc.
Maybe I would reverse the selection: After () Don't select (). That way, it follows the playlist order, which makes more sense.
One question: What would Less than and More than mean for Comment, Gender, and Language?
RadioBOSS 7.1.0.3 beta
Changes
  • Updated user manual
  • makelibrary command extended to add tags on update only for tracks with no tags (optional)
  • Playlist Generator: extended log option for priorities (can be enabled in Advanced settings in RadioBOSS)
  • Playlist Generator: export/impoer of constraints rules
  • Ads Scheduler: Test all blocks feature shows a reason why a block has a warning (hover a mouse over a cell)
  • Ads Scheduler: fixed some accessibility issues
  • Default intro/outro option: not applied for file types
  • File Types: added "Treat as music track" option to allow applying Time Stretch and other features to file types
  • Added scheduler command to turn Time Stretch on/off
  • RemoteVT: fixed VST plugins can not be used
  • Fixed: voice track bed was not properly applied sometimes when bed was configured for a file type
  • Fixed: presets in Ads Scheduler can not be deleted
  • Fixed current track artwork saving
  • Fixed: prelisten in Track Tool did not mute the main playlist sometimes
  • Fixed: AUX players did not work properly sometimes with AUX1/AUX2 devices
  • Fixed: Playlist Generator did not start in Trial version
  • Fixed: UAC UI bug in Cart wall
  • Fixed: global hot key can not be removed
x86 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.3.exe (2/21/2025, 34MB)
x64 https://dl.djsoft.net/beta/radioboss_setup_7.1.0.3_x64.exe (2/21/2025, 38MB)
Remote Voice Tracking
https://dl.djsoft.net/beta/RemoteVT_setup_1.0.0.2.exe (2/21/2025, 7MB)
There are two options: Playlist -> Add track list, that's for adding new Track List items, and right-click, Tools -> Edit, which will edit a playlist item, calling the appropriate editor, based on the item's type.
I would like those two options to be able to be blocked or hidden from other users.
I added this for the future improvements list.
excellent.
Thank you so much for the update. Question. Do do the voice track bed fade out settings now work for beds that are configured for a file type? Because I'm testing it now and not hearing a difference. The beds still don't fade out when configured for file type. Unless I'm doing something wrong? Within the file type window there are no visible settings to control fade out parameters for music beds - these are only currently found under the Voice track settings window. Is fading intended to apply universally once you adjust it in the Voicetrack settings window? Because it's not working under file types.
Changes
Dear Team RB,
Although the "Treat as Music Track" feature is added and enabled for the Time Stretch feature, the playlist behaves strangely. It does not calculate up to the end of the hour. While the stretch calculation appears on the first track ( Playing Track ), it often does not update after the second track starts playing. I tested this with two file types (Jingles and Music), both enabled with the "Treat as Music Track" feature, and the issue persists.
Thank you
This is a wonderful settings feature indeed. Would it be possible to make it so that this would apply also for voice track attenuation settings? Such that attenuation would only apply to file types selected as music tracks. I may want the music to fade into and out of voicetracks, however if I have a sweeper or other station imaging following a voice track, I would require no attenuation. Currently the attenuation settings apply universally to all file types, yet in most cases would only need to apply to music tracks.
Yes, currently it's only able to select a random intro. One of the reasons is that "In order" will have to track what it's selected, and also handling cases of added/removed files. Which makes this feature unnecessary complex.
This could work if you properly set the cooldowns. There may be cases when the first rule of this chain will be used more frequent than the other rules.
Can you please specify what happens?
Yes, this makes sense. Will be added in the next update.
Probably you're right. Noted also.
For less than/more than it converts the string to a number, then compares those numbers. If the string is not a valid number, it will be treated as zero. So comparing any non-numerical strings will result in "equal".
To clarify, you want to prevent the users with "Edit playlist" right to be able to call the "Edit item" command in the playlist, and also prevent them from adding Track Lists? Even if so, they will be able to import tracks from the playlists and still able to add Track Lists (or anything else) this way.
When a file type has "Voice track" option, its bed will be treated with the settings from the Playback -> Voice tracking window. File type bed itself doesn't have any fade in/out settings for the bed because it's faded out with the track itself (according to Crossfade settings - track and bed are mixed to a single stream and it's faded).
What happens after it plays the first track, does it reset the time stretch speed adjustment?
At this point it wouldn't be possible to add this, as when a voice track is played it attenuates the entire mix of the music, not caring what's played there (file type or not). Maybe in the future updates but not now as this big change will require a lot of testing.
What's new
  • Introduced new RadioBOSS Ultimate edition. RadioBOSS Express edition is deprecated.
  • RTMP streaming support
  • Remote Voice Tracking module (Ultimate edition only)
  • Time Stretch feature: change playback speed of the tracks to make end at hour end (Ultimate edition only)
  • Remote control API: possibility to create users with limited rights
  • Style option: scale the secondary windows by set percentage
  • Nowplaying bar size option: Large (menu View->Top panel->Large)
  • Track List presets for repeat protection rules (Track List entries can now have different repeat protection rules)
  • Global hot keys added (menu: Settings->Hot Keys)
  • New tab type: Log
  • Containers in the playlist can be named
  • UAC: certain cart walls can be unlocked to
  • File type identifier for containers (container=)
  • File types: default artwork option
  • Logs: add track titles to the log when a network stream is playing
  • Sweepers: option to combine multiple sweepers
  • Sweepers: specify minimum duration to sweep
  • Scheduler: override artwork for streaming and export for scheduled items
  • Scheduler: added a command to render playlist to a file (renderplaylist)
  • Auto Intro: added "Cooldown" option for the rules to prevent a rule from being used too often
  • Auto Intro: added separate fading settings for Auto Intro (previously used settings for voice tracks)
  • Auto Intro rules based on file path
  • Track List: a music library can be used as a source
  • New playlist columns: Event name, Event waiting, Segue Editor, Track Tool, Voiceover, Mix
  • Waveform drawing improved (better precision) for Track List and Segue Editor
  • getfile command: added option to select files in order (alphabetically sorted)
  • Scheduler: added "Expires" column in the scheduled events list
  • Log: filter entries by file type
  • Search: added Language field
  • Text to Speech: %hp variable for 12-hour clock
  • Voice Tracking: separate fade in/fade out settings for the underlying music
  • Voice Tracking: default Intro and Outro values for tracks with no intro/outro set
  • Voice Tracking: recordings are now saved in FLAC format instead of WAV
  • Broadcasting title can be added for Teaser items
  • %filetype variable for HTTP requests
  • Advanced option: prevent clipping when using EBUR128 normalization
  • Advanced options: Fade In and Fade Out for voice track bed
  • Logarithmic/linear volume option now also applied for the AUX players
  • Removed ANSI encoding from HTTP notification settings
  • Reduced rate of error notifications when there are too many errors
  • Added "songrequestclear [age]" scheduler command
Ads Scheduler
  • Bulk edit ads in the list
  • Added new options for the generated scheduled events (name container, start event earlier)
  • Added warning: when a number of ads in a block exceeds certain value
  • Export process is logged to a file
Playlist Generator
  • Constraints: specify rules, which tracks can follow which tracks
  • Repeat protection rules based on Tags
  • Option to detect track remixes for repeat protection
  • Command line option to specify the number of playlists to create for each preset
Music Library
  • When updating the library automatically, it can assign specified Tags for the newly added tracks (makelibrary command also extended to add tags)
  • Added Cue In/Cue Out/Mix columns
Segue Editor
  • Improved precision for defined track and mixing positions
Fixed
  • Fixed: rendering playlist to a file didn't work properly with voice tracks
  • Fixed: repeat protection rules were not checked when rendering playlist to a file
  • Fixed: grid preset list was not updated sometimes in the Ads Scheduler
  • Fixed: streaming title was not sent from the Overlay players sometimes
  • Fixed Playback Queue bug when one track was added to the queue multiple times
  • Fixed: processed tracks counted in the Music Library sometimes was incorrect
  • Fixed TTS macro processing for overlay playback
  • Fixed: Playlist Generator sometimes did not take into account clock adjust option in RadioBOSS
  • Other minor fixes and improvements
License key
The free key expires May 15, 2025.
RadioBOSS 7.1 beta
Utility to remotely add voice tracks and edit playlist
RadioBOSS Ultimate
Upgrade to RadioBOSS Ultimate from your current edition at half the price during the beta, click the appropriate link:
RadioBOSS Express to Ultimate
RadioBOSS Standard to Ultimate
RadioBOSS Advanced to Ultimate
Check on Advert, when you set and rename presets, you can not delete or remove it, seen the picture 👇
Hello. I'm thinking more and more about how we, with screen readers, can come up with those advanced options. One of the solutions could be to put those options in advanced.INI files and then we who know how to handle INI files can activate the options from the Advanced section that we need.
The stretch speed time adjustment disappears soon after the next track starts. I tried playing tracks from different positions within the playlist to see if it would start working again, but the issue persists. In most cases (around 90% of the time), the stretch speed time adjustment is not applied at all.
There is a problem, I don't see the "container file type" in the file types list. Do I have to add it manually?
Another problem is that when packaging a SWP/ID/JINGLE with the time announcement in a container, only the SWP/ID/JINGLE is played and not the time announcement.
I have been having the same issue with teaser presets. One trick I use is to delete them from the presets folder. For teasers, I have found that this works.
It also doesn't play "network stream".
and you see a line in the playback status bar when playing a container
