Auto Intro
three questions about the "Auto Intro" function
  1. is it possible to select the days in which it will be broadcast?
    For example, only on Monday for stations like "happy Monday" or only on Saturday and Sunday for stations like "happy weekend"
  2. is it possible to select a time slot in which it will be broadcast?
    For example, only between 07:00 and 11:00 for stations like "good morning"
  3. is it possible with RadioBOSS to program 2 spoken stations in sequence that arrive up to the intro of the song?
Thanks and have a good weekend everyone
In the shheduler, there's set auto intro on (off) command to enable/disable the entire auto intro feature when needed, and also autointro command to control individual rules: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm
Before writing this ticket I had already read and studied the page at the link you sent us.
After 3 days from your reply and after continuing to study, unfortunately I cannot find the answers to my 3 questions (probably due to my technical limitations for which I apologize)
If you think so, please answer each of my three questions, at least with a yes or a no.
thank you
There is a lot of info on that page, but this part may help:
"autointro [disable|enable] rule1, rule2, ...
Enable or disable Auto Intro rules. Rules names are not case sensitive.
Example: disable rules Morning and Day
autointro disable Morning, Day
Example: enable Artist rule
autointro enable Artist."
So, in the example where multiple rules are disabled at once, which was "autointro disable Morning, Day," it appears that you simply enter that text as an event. No need to use the wizard, just enter the command containing what rules should be enabled or disabled, set the schedule for the event to run, and all should work.
I haven't used these yet, so I'm not going by experience here, just summarizing a section of the manual as I understand it.
