Questions about the latest update’s functionality
jopara
Hi, I have a few questions about how some features work in this latest update.
  1. Teaser function issue:
    In the scheduled events, I’ve ticked the box: “Send to the server on behalf of the event instead of track titles” and set “Set artwork” with a specific cover. This should display the event’s title on my website (which it does) along with the selected cover (which it doesn’t). My website already has the function to show covers and track titles, as mentioned in this forum. Is there a way to display the custom cover only for Teasers?
  2. Unexpected behaviour after the update:
    • After disabling an event in the scheduler, it reactivates itself automatically around midnight without any apparent reason. It’s as if everything resets at that time and triggers the command alone.
    • I also use the “disablegroup” and “enablegroup” functions to toggle event groups on holidays. The last time this worked was on 1st May 2025 (a public holiday in Spain), which I have set for annual use. Could this be related to the issue?
Thanks in advance for your help!
From where does the web site gets the cover? The "Set artwork" option for scheduled events will make it save artwork to a file, export it to FTP (if enabled) and %artwork variable in HTTP requests will contain the set artwork.
Looks like the enablegroup is what's enabling those events. You should check the Logs section, there you will see what events were started and what they did.
