Voice track issue after the currently playing song
madein80
Hi,
When inserting a voice track right after the currently playing song, it doesn't take the outro point and the intro point of the next track.
It's starts after the intro has finished.
However, there is no problem if the voice track is placed between the second and third songs (or later).
This bug only occurs immediately after the currently playing song.
I'm referring to a voice track created directly in RadioBoss, not using the Remote Voice Track feature.
Yes, it's a known error and it actually sometimes works as it should. We'll eventually fix it in one of the next updates.
Thanks because it's really annoying for me. I have a script system that inserts the voice track after the song we're playing.
I'm going to check on my side. Is it a major fix? Is it planned for an upcoming update soon?
The main problem is that we were never able to reproduce it here. Some work in this direction was done in 7.1 (actually lots of changes in voice track handling) but we didn't see the problem in the first place and it also doesn't present now when we test it. We have occasional reports from users about it but for now we did all what we could. Eventually this will be fixed as a result of working on the software/or maybe we'll be able to reproduce it which will allow to quickly implement a fix.
If I can help move this issue forward in any way, it would be my pleasure — on my end, the problem occurs every time.
Can you please do the following, before the voice track is inserted:
Press Ctrl+F4 to open the debug window.
Make a screenshot so that both main window and this debug window is visible
Insert a voice track and make a screenshot
Also screenshots of Track Tool window for both music tracks (before/after a voice track) and of the voice track itself
This should help, or at least be a start.
Perfect, I’ll take care of it this weekend.
