Played Song List
Flashback
I miss a feature in Radio Boss that would be really helpful to me. A list of the last 3 songs played. When I present de songs I use to say the last three songs played. It would help me a lot if I could have a window or something like that that would show the list of songs last played.
You can see it in the Logs section, and also if you hover the mouse over the "Last Played" box in the main window, in the tooltip it will show the last 5 played songs.
Thanks for your explanation, but I don't use the log section open, but even if I did, It is a real mess 'cause it shows everything that was done and not only the name of the songs played, and it's not possible to set it to show only the information that is useful for you.
The "LAST PLAYED" only shows that information for a few seconds. Thanks again!
I don't think this feature would be difficult to implement. In fact, it's already implemented in the "LAST PLAYED" as you said. It only needs to have a place where you can easily access it. What about a TAB? What about a Field in the working area of RB?
why not uncheck queue mode ( delete played tracks from the playlist)
You can right click the log to set up filter, one of the options is to only show the music tracks. Additional Logs tabs (with filters enabled) can be added to the additional work zones: https://manual.djsoft.net/radioboss/en/work-zones.htm
Thanks, it worked fine! Is there a way of increasing the size of the letters in the log zone? I did that in the playlist, but I didn't find a way to do it in the extra work zone.
How can I add the name of my radio in the list of the stations that use RadioBoss?
I don't know if it works with you, but with me it never worked. Even if it is checked or uncheked all the tracks keep on in the playlist.
Queue Mode will not delete music tracks in certain cases, e.g., when the "Repeat Track" option is enabled.
