Suddenly no more Music Beds
Jörg B
I have already reported the following error multiple times, but have not received a satisfactory response. In our news broadcasts, a file named news.mp3 is played. Similarly, in our weather reports, files are played depending on the time of day: Wetter00, Wetter06, Wetter09, Wetter12, Wetter14, Wetter16, and Wetter18. The file news.mp3 is assigned to a category called "News," and the weather reports are assigned to a category called "Weather." Each of these categories is linked to a music bed. It keeps happening that after Radioboss has been running for some time, suddenly, without anyone intervening and without any apparent reason, the music beds are no longer played. It is important to note that, for example, everything was working normally until last night; there were no changes, not even a system restart or anything similar. Suddenly today, the music beds can no longer be heard. Therefore, it cannot be due to a misconfiguration, as everything had been working properly. The Main System is running Radioboss 7.0.8.0 X64
I have now done the following: I restored a backup of the RadioBOSS settings that was automatically created during the night. After restoring this backup, the music beds are now back. This backup originates from a time when the issue with the missing music beds had already occurred. Nevertheless, it is now working again. Only two team members have access to the Windows server on which RadioBOSS runs, and no one except these two, myself, and our IT officer has access to the RadioBOSS API. Therefore, it is impossible that any changes were made that could have led to the sudden disappearance of the music beds. The fact that they are now working again after restoring a recent backup points to an unspecified error or inconsistent behavior of RadioBOSS in this case.
Beds were severely reworked in the 7.1 release so I suggest installing it, most likely, it will fix the problem you have.
I'm not sure how RadioBOSS can the cause of this. If it was, most likely, the beds wouldn't have worked at all if there was some bug (and there were some in 7.0 and prior versions).
"But when I install version 7.1, other problems appear, which I have already reported here in the forum. For example, issues with the automatic creation of playlists."
"And I can only report what I observe. Nobody changes anything in the system, and suddenly the music beds are no longer audible. All the files are still there and, for example, are played correctly within a playlist, and the event is executed properly. Sometimes restarting RadioBOSS helps to get it working again, but sometimes only a full restore of the settings solves the problem. However, it is strange that the backup does not contain anything different compared to the settings currently in RadioBOSS. The settings backup is created every day at 3 a.m., meaning that the restored backup was made after the error, the 'disappearance of the music beds', had already occurred. I cannot explain it either. But that is how it is."
Currently we can't confirm the problem with creating the playlists - they seem to be creating fine here. Do you use the generate command or you make it create a playlist and save it to a file (the command in the event looks like run PlaylistGeneratorPro.exe...)?
Maybe something's changed that is not obvious. Still, you say that it happens in version 7.0. You should try the latest version 7.1. Previous version will not be updated anyway.
I am still experiencing the repeatedly described issue that music beds assigned to certain categories suddenly stop playing, even though no system changes have been made — at least none that affect the music beds or the related categories.
Here is an example:
A file named "news.mp3" is assigned to the category "News." This category uses the folder path e:\audio\news\news.mp3, and this path is never changed. Therefore, any file located in that folder should logically be categorized as "News." As a result, when I say “use music bed” while "news.mp3" is playing, a music bed should logically be played.
And that does work — for a while, usually several days — until suddenly, music beds are no longer played in any of the categories where I use the same setup, for example, also in the “Weather” category.
Sometimes, simply restarting RadioBOSS solves the issue and everything works as expected again. In other cases, I need to restore the settings. I always use the settings that were automatically backed up the previous night — and no changes have been made since that backup. Still, after restoring, the music beds start working again.
I will now document in this thread when the issue occurs and what actions were taken.
As of now — June 20, 2025, 12:50 — I have reloaded the settings, and the music beds are currently functioning correctly again.
I will report again the next time the issue occurs and document what has happened on the server in the meantime.
RadioBOSS is running here on Windows Server 2019, Standard Edition, as a 24/7 automation system, and it’s very disruptive to have to constantly restart RadioBOSS or reload settings.
I'm not sure why this could happen, the problem doesn't reproduce here, and also beds and file type processing inside RadioBOSS is state-less, that is there's nothing that can possibly "accumulate" over the days to prevent the beds from working - each track play is independent, and beds are also assigned from scratch (nothing is re-used from previous plays). Do you see any error messages in the log?
Hello, I’m reaching out again. Today, on July 6th, 2025, during the hourly news at 05:00, the music beds failed completely once more.
From my last report until today, everything had been running smoothly. There have been NO changes made to the system since then. RadioBOSS has been running as the radio automation software 24/7.
The following events were used:
  • Playlist creation via Playlist Generator Pro
  • Playback of specific tracks at specific times
  • Daily update of the libraries
  • Hourly playlist loading
  • Daily backup of settings at 04:00 a.m.
  • Relay commands for different streams from live broadcasting hosts, as well as stopping the relay after each show
No updates have been performed, and no system variables—such as access permissions—have been changed. The music beds are still located exactly where they were originally stored.
In short: there is no identifiable reason for this issue. There are also NO errors visible in the logs.
After reloading the RadioBOSS settings—which were exactly the same as before—and restarting the system, everything works correctly again. For a while.
This happens to me sometimes and I usually have to restart Radioboss for the beds to start playing again. Not sure what the cause is, but I've noticed it happens much less frequently with the latest update.
I wanted to add that this also occasionally occurs when rendering (mixing down) the playlist. The beds sometimes don't appear under the voicetracks when you render. Not always, but sometimes.
After rendering, they also do not play in the playlist? If you use multiple beds, please check if all of them are actually playable.
I meant that when I render, the voice tracks will appear in the mixdown but sometimes the assigned bed won't be heard beneath the voice tracks yet during normal unrendered playout they will be heard. So I'm pointing to two issues - first being that *sometimes* the beds won't accompany their assigned voice tracks during live playlist play back. And second - that when I render, sometimes (not always) I won't hear the bed in the mix. The error is kind of sporadic.
Interesting, I think we'll start with improving diagnostics - it will log when the bed can't be loaded and state the reason for that.
