nowplaying HTTP notifications when live stream?
Ben Kempink
Is it possible to use "nowplaying HTTP notifications" with live stream? I use 'get' and works fine with playlist, but not with live?
Am I doing something wrong?
Notifications are sent for the tracks that play in RadioBOSS Cloud, they are not sent when a title is updated on live stream. Can you please specify when it is needed?
Just like your API provides the artist = title for live, it would also be desirable for this. HTTP notifications use much less data traffic.
I'm sorry for misinformation, since a few updates ago, the notifications (HTTP request, Twitter updates etc), are also sent for live streaming as well. Can you please check if the request is still not made? The notification is supposed to be sent each time a title in the live stream updates.
Thanks, we did check last month. Nothing when a title in live stream updates. And nothing in the log. But we'll check again. We let you know.
Unfortunately, during live broadcasts no “now playing HTTP notifications” are sent. The log shows the “playlist songs,” not the songs from the live broadcast. Hopefully you can fix this.
We found the solution! You have to enable "Enable TuneIn and Twitter integration when broadcasting live" in settings, streaming!
The Logs section will show tracks that were playing in the playlist, in the Recent Tracks area (Overview section, or in the widget), you can see track titles from the live stream.
Those are separate features, you need to enable HTTP Notifications in the settings, and only enable Twitter/Tunein if you need them.
In settings there is no ‘enable http notifications’, only ‘TuneIn and Twitter when broadcasting live’. In integration there is http (as well as TuneIn and Twitter). I have enabled http there and disabled TuneIn and Twitter. In settings → streaming, ‘enable Twitter and TuneIn notifications’ must therefore be enabled for http to work.
Thank you for clarifying, it's an error on our part, the caption for this checkbox should have been updated to "Send notifications when streaming live". We'll fix it in the next update.
