New Intro Point A and B
matteolop
Hi, some well-known radio broadcast software has been including the ability to add up to three intro points in their Track Editor for many years.
Since I'd like to see this feature, including in RadioBOSS, we could currently limit ourselves to up to two Intro Points and a new Start Point for Auto Intros or Voiceovers only (I know it's already partially present).
My request is the following: I'd like to set the start point, where exactly the track begins to play, the Intro A Point where the most "lively" part of the song begins or where the "kick" begins, and finally the Intro B Point where exactly the singer begins to sing.
All of this is visibly managed by different colors and a progressively moving bar.
Some radio broadcast software also has the exact same feature for the Outro Point (Outro A and Outro B).
Having multiple points set on the song, I think it might be more effective to decide exactly where the speaker should speak.
At one point during the day, you might start speaking from Intro Point A, and at another point from Intro Point B.
(Or even depending on the time available for the talk.)
I invite you to look at my attached photo and listen to the song "Elton John, Dua Lipa - Cold Heart (PNAU Remix)" that I used in the reference photo.
I hope you can integrate this feature, and I'd love to hear what other users think.
This sounds interesting, however I think we should wait and see what other users have to say about it.
If there are two or more intro/outro points, what "intro countdown" will show, or should there be some sort of switch between A/B markers?
Point A would be the current intro point.
The second intro point (point B) is an "extension," or "completion," of the intro.
Even though they are executed in action, they are executed in the following order: Intro point A starts and reaches intro point B, then intro point B continues until its end and the singer starts singing.
In the absence of Point B, only Point A will be activated, and the Point B button cannot be enabled/validated without first setting Point A.
(You can also apply this reasoning to Outro, but currently I see it working more for the Intro).
On a graphic level, you can redesign the PLAYER and INTRO user interfaces.
You can create a moving bar that will light up (or remain fixed and then dim once the intro command is executed) when at least one Intro Point is present, and the colored progress bar will move smoothly to the end of the horizontal segment.
When Point B is set, the colored progress bar (from Point A) will move for x seconds, then transform into Point B, where it will take on a different (but similar) color, indicating that we've entered Point B and are approaching the true end of the intro.
It's the same concept as now, except that they're divided in half, all managed by dedicated lines, colors, segments, and colored seconds.
Furthermore, you'll need to keep all the data and parameters set for the current songs in the archive and database valid, and the song's current "INTRO" value must be automatically converted to the new word "INTRO A," and if set by the user, the "INTRO B" point must be added later.
You can see in my photos that I've attempted to design a sort of user interface with the playback line advancing, bringing the two intros (A and B) to life and adding color.
The two colors and segments automatically adjust based on the duration and distance between them.
This is the definition of the current Intro/Outro points in RadioBOSS, Intro is where the vocals start, and Outro is where it ends. This is how most tracks are already marked by the users. So the current Intro/Outro look like what you describe as Intro B/Outro B.
At this point, I'm not sure if the second intro will be useful, this will bring confusion for sure - Intro/Outro are used for automatic voice tracking.
I understand.
So all the current intro points would be "Point B" and, if desired, a second intro point could be added (which, however, would be called "Point A").
I understand.
Yes, it could, but I'm not sure about how useful it would be for others.
There's no need to create confusion.
If the second intro point isn't touched/added (you decide whether to call it "1/2" or "A/B"), it won't alter any current behavior.
If only the second, new intro point is added, then buttons will be used to decide when and how to activate voice intro or auto intro.
Either from the first or second intro point, or a checkmark for "AUTO" will let RadioBOSS intelligently and "radio-friendly" the choice.
For example: if I have a slow male voice, it should play it over a slow, male song, and vice versa if it's a female song.
There are many things where Intro is used - Voice Track, Auto Intro, countdown timer for intro, maybe even somewhere else. Adding another Intro value will certainly bring confusion and lots of additional options like "If Intro A is not set then use Intro B / Use Intro B with X offset / some other option". I'm not sure it will bring a lot of value (compared to development effort and documentation update and support costs).
Maybe it can be added as additional feature, turned off by default, so at the point when one finds it, they are already familiar with software so less chance of confusion :)
I think it could be really useful because today songs have strange structures, sometimes there's is an outro but with a lo-fi voice track by the singer, sometimes there's is 30 seconds intro with 3 steps of evolution... Thanks for your idea @matteolop
Best
Best
Exactly, exactly!
That's why I proposed the idea...
I think that in 2025, two intro dots isn't enough for a local FM station that does a fine job.
I hope the Radioboss team implements this feature. ;)
It's not a big deal to add this, the big question is how to actually use it, add more settings, e.g. for voice tracks use intro/outro set 1, for other reasons use set 2?
From what I've learned and seen in use from other third-party software, it worked based on colors.
The intro bar scrolled a certain color until Point A and then until Point B (or Point 1 to Point 2—you decide what to call them).
After that, once you've set up the new intro points throughout RadioBOSS, you need to add more controls for Voice Tracks and AutoIntro, and have the user define whether to choose Point A or Point B, or "Auto" and have RadioBOSS choose randomly.
As far as I'm concerned, I only want it for aesthetic and sound reasons.
At the moment, I'm only interested in more intro points, for greater precision and cataloging of the songs in the archive.
Because, as one user said, songs currently have very different and unique intros.
See the first photo I attached to this post.
(I would like other users to join the discussion to propose valid solutions regarding this new feature.)
Pelo que aprendi e vi em uso com outros softwares de terceiros, ele funcionou com base em cores.
A barra de introdução rolou uma determinada cor até o Ponto A e depois até o Ponto B (ou do Ponto 1 ao Ponto 2 — você decide como chamá-los).
Depois disso, depois de configurar os novos pontos de introdução no RadioBOSS, você precisa adicionar mais controles para Trilhas de Voz e AutoIntrodução, e fazer com que o usuário defina se deseja escolher o Ponto A ou Ponto B, ou "Automático" e deixar o RadioBOSS escolher aleatoriamente.
No que me diz respeito, eu só quero isso por razões estéticas e sonoras.
No momento, estou interessado apenas em mais pontos de introdução, para maior precisão e catalogação das músicas no arquivo.
Porque, como disse um usuário, as músicas atualmente têm introduções muito diferentes e únicas.
Veja a primeira foto que anexei a esta postagem.
(Gostaria que outros usuários participassem da discussão para propor soluções válidas em relação a esse novo recurso.)
Obrigado:)
BOA IDEIA!!!!!
Hi, will this be included in RadioBOSS 7.2? When will you start releasing beta versions with trial keys? I can't wait to see the new features. Thanks!;)
I'm not sure yet as the version is under development and will be released in February with whatever features are ready by the time.
