Music Library - 1 track present in multiple databases functionnality
Altec
Hey Dmitri,
I'm using multiple database in the Music Library to create selections of songs, it permits to have fewer songs in the database and reducing importantly the generations time in playlist generator, it permits too to have less tags in the tag list.
Can we imagine a functionality to be able to view for example in the tracktool which databases the file is already present in, for example a menu with checkboxes to add the title to a particular database. Or to imagine a subdatabase system to have subdatabases to create new categories possibilities and reduce the size of databases.
I have approximately 10 000 songs, and it's more than 1 hour to generate 24 playlists, especially when you are using filters and additional priority rules
Best regards
Do you use the latest RadioBOSS version - there were lots of speed improvements in version 7.1. Also, 32-bit version, according to tests, works faster than 64-bit (when creating playlists using the Playlist Generator and also in Ads Scheduler).
Yes, I think it will be possible in one of the future updates, thank you for the idea.
Yes I'm using it, but I detected that Additional priority rules + tags filters slowed down considerably the generation
Nice !! Thank you, if you need more details of my idea I can develop.
Best regards
It linearly depends on the number of music tracks you have and the number of rules. Processing is parallelized, where possible (e.g. priority rules, so the more cores you have the faster it'll be). Also, 32-bit version is about 30% faster that the 64-bit. If you use the latter, consider switching.
Why, it should be the inverse ?! Because my server's working on a 64bits architecture.
Could it be fixed soon ?
Probably it should, but the tests show otherwise, both Playlist Generator and Ads Scheduler work faster in 32-bit version (when run on a 64-bit Windows). So, if you need the solution now, just use 32-bit version.
