RB 7.1.5.1 Scheduler Causes Reboot of RB upon changes.
TRGlobal
Just updated to RB 7.1.5.1
Experienced in use of RB as I have now 5 licenses and running automated.
Latest Problem on my new PC, and new RB install (twice) is that the RB Scheduler while running if I make and update/change anywhere in the schedule more than once will cause RB to STOP and REBOOT. RB Scheduler lets me make ONE CHANGE....AND even if I save that change immediately, RB will still reboot if I try to do the second change, the scheduler window to fill in the change is all WHITE OUT in color and immediately goes into REBOOT of RB. SO this causes the playback to stop while RB reboots. This has never happened before in any other version and not happening on any other machine.
New PC has 32 GB Ram and running windows 11 PRO, and plenty of hard drive space several TB free. My other 4 online stations allow me to make changes to the Scheduler while in operaton.....?? I even tried RESETTING the PC to see if that would make a difference....NOPE?
Bad choice of words, the Pc does not REBOOT, just RB stops and closes itself. PC stays running...it starts right back up again and lets me make 1 (only) change/update to the schedule....runs fine.....then if I attempt to make second change the pop up window comes up with all the fields whited out and RB closes by itself.
Can you please provide some steps to reproduce this behavior? A quick test does not confirm this problem, editing an event then editing the same or other event does not lead to a crash/closing here.
Maybe RadioBOSS was able to capture this error - please in the menu click Help->Contact support->Send bug reports.
Picture of POP-UP to modify event in Scheduler
RB installed 4 times..64-bit...even installed 32-bit version to see if that helped....it did not.
Only happens on my newer gamer type PC to run the TV station.
While RB is running, Scheduler is showing the files it will run. If I click on an event and choose to make an EDIT, then save it, all is OK. But if I go and try to modify a scheduled event OR ADD Event a second time, this is when the pop-up window shows to make the change...it is the PIC above. All the fields in the pop-up are "whited out"....and locks up RB and after about 10-15 seconds will cause RB to Close and reopen again. Then the process will start anew....after reboot, it will once again allow me one time modification and the second one NOPE. THIS HAS NEVER HAPPENED BEFORE WITH ANY OF MY OTHER PC'S. NOW, very rarely, it will work as normal....very rarely. But when I shut down or open RB again, it will do the above "almost" all the time. PC is Win 11 Pro, Up with all the latest updates, 32 GB RAM and over 4 TB drive space open. This is my Templar TV server. I am not broadcasting with RB, just using the scheduler to run audio and video files and I capture the display in OBS. The ERROR happens whether I am using OBS or not. OBS is not loaded and the error still happens. Just running RB by itself causes the scheduler issue.
I did a, mdsched.exe Windows memory check of the 32 GB Ram and no problems found. ?? On this reinstall of RB, the issue above exists All the Time.....one change only to scheduler then lock up and close of RB is automatic.
This is certainly a system-specific problem (happens only on your computer). Probably you have some odd 3rd party software installed that leads to this behavior. One thing you can try is to enable the standard Windows style in RadioBOSS's Settings / View / Style - in extremely rare cases, custom themes do not work right.
Also, does it always happen with the same events? For testing, we would need your events list, please click List, Save, then send us the saved file, we'll try to reproduce it here.
Any changes to the Scheduler....anything I do even just change the time/seconds of an event RB will work once, and after I save it, then as soon as I Choose EDIT again for anything, the pop window will appear all fields white out and locks up RB and causes reboot. LOG shows NO ERRORS, NO EVENTS what so ever. This is perplexing.
I will install OBS which is basically the ONLY other software that is not on other machines.....I will install it on one of my other pc's currently running RB and broadcasting to see if that makes a difference and replecates the same error. I will let you know.
I am at a loss.....just d/l and installed OBS on Radio 2, opened it up and could NOT replicate the issue on the TV1 pc. Made multiple changes to the Scheduler and nothing happened....RB kept working as normal.
My Radio 2 currently running RB software with no issues. Loaded OBS (TV) software on it, and rebooted, started RB and OBS. RB worked fine, no issues, made several changes to the scheduler and RB kept running fine. Again points to the TV1 server issue only. I am at a loss as no additional specialized software is on that PC, basically stock programming as it is an OMEN Gamer PC to handle the TV video.... 32 GB RAM, I checked the RAM, no issues. Win 11 has all the updates. I just do not understand why RB on that PC .....the only issue is can't make more than one Scheduler change without CRASH.
Tried another fix.....I reinstalled RB on my D Drive........separate from the original installation on C: drive. The same thing happens, NOTE: all I have to do is open scheduler.....not even make a change.....once Scheduler is opened that counts as my 1 time I can use it. So I clicked on a file.....made NO CHANGES to it and Cancelled it. Then I picked another file and as soon as I hit EDIT and RB locked up, crashed and rebooted. I am running out of things to check....with this...
OK....I believe problem has been solved. OPEN RadioBoss with "RUN AS ADMINISTRATOR" has fixed this ISSUE. I will use TASK SCHEDULER to start RADIO BOSS a few minutes before the TV Broadcast.....Task Scheduler - RUN WITH HIGHEST PRIVILEGES has resolved the aforementioned Scheduler Events CRASH issue. WOW, woke up at 3 AM Eastern Time this morning with this on my mind. So, I came out to the studio and tried it, and worked first time...... AS Pink Panther (movie)
Inspector Clouseau would say, Problem Sol-ved !!​
Never seen this issue with ANY OTHER PC......seems completely RESOL-VED NOW.
Maybe the PC had with some 3rd party software pre-installed and it's what is causing the conflict. If this is a new PC, they usually come with loads of questionable software pre-installed. It's usually a good idea to create a USB installation disk for Windows (https://support.microsoft.com/en-us...-windows-99a58364-8c02-206f-aa6f-40c3b507420d) then make a clean Windows install, re-partitioning the hard drive (to ensure that everything is wiped out).
Generally this should not be used as it may (probably) lead to unwanted side effects. RadioBOSS does not need admin rights to run.
