making an event to play a file from a play list every time its called
derek
What is the best way to setup an event so that each time it is called, the next file on a playlist is cued? This would be a very efficient way to handle short audio dramas that need to be played at a particular time.
If I understood correctly, maybe you need to call the next command from the event?
