If you launch it via the scheduled event, and the event has "Send task name to the server" option, the event's name will be sent - not the actual track title from the stream.
In this case you will see the event's title - not the title you see in the Track Information panel.
You can enable the "Broadcast title" column in the playlist, it will show you what titles are sent.
