Recommendation for improvements to ins voice
cheodj
Hello, the INSVoice feature works perfectly, but it would be great if the expiration date for these voices wasn't limited to that section. I recommend adding tags to identify them within specific songs or artists, and creating a command to enable or disable INSVoice where users could select the tags for voices they don't want to play at certain times during the 24-hour programming. Another suggestion is to be able to select two or three points within a song where the INSVoice should play, similar to the recommended intro (A and B) points. Hopefully, you could also add two or three points in INSVoice to apply to specific artists or songs. It would be fantastic if this could be added in future updates, or at least the tagging feature could be implemented with a command so that users could disable certain artists or songs in INSVoice. I'm not sure if I'm explaining myself clearly, but it would be helpful if the `enablevo` command included the tag name, for example, `enablevo Bee Gees` or `disablevo Bee Gees`. I hope you understand. Thank you.
Yes, I know it can be done through auto-intros, but imagine how many auto-intros you would have to create for the songs you want to include with the artist's name and song title. I think that option would be spectacular if it were in ins voice, so you could change voice by tag.
The Voice Insert is mostly a manual feature, to allow adding voiceovers where they are needed, while Auto Intro is designed to be mostly automatic/unattended, adding intros for any number of tracks. Probably it would be easier to define Auto Intro rules for each artist you have.
Yes, I fully understand that auto-intros are designed to automate any generic comments, in this case about a specific singer or song.But it would be really interesting if the same auto-intro function were available for INS voice, since that way you could add a voiceover comment about the song and It's announced within each MP3 file, and the auto-intros are used for generic sweepers or any generic commentary about the artist, not about the song. It really is One recommendation: track tools should be configured when the MP3 is inserted and all its markings are made, including the voice track off.
You can insert voice or anything else using the Auto Intro feature. Setting up Auto Intro rules allows to determine what tracks will get this intro file.
When using the Voice Insert, you will have to add this voice file manually for each music track. If you're OK doing this, then later all/some Voice Inserts can be turned on/off by renaming the voice files themselves. E.g. you add "announce.mp3" as voice insert for a track. If you later remove/rename this file, voice insert will not play.
Okay, what you say is also valid, but it would be really great to have the same configuration used for auto-intros in the Insert Voice settings, because you can select the folder where they will be stored. The voices can be rotated randomly and that is programmed only once, I hope you understand me this time.
This looks like a feature duplication, I'm not sure if we'll be adding the same configuration as Auto Intro has to Voice Inserts.
What is the end result that you want to achieve?
Perfect, I was just suggesting it was a good option in that section. Thanks anyway. For me, RadioVoice is an excellent radio automation tool, but they should consider future connections with... Artificial intelligence. Thank you for your attention.
