Server connection closed
Hi, on more than one occasion when switching the broadcast from audio mix to input ! it freezes on air and the message server connection closed output 1 restarting appears. I have to wait a few minutes for it to reconnect, while other times it switches without any problem or message. What's the problem?
I checked a similar message but it is not our case, when rb is in audiomix it never stopped, only when switching to input 1 the problem occurs but not often, sometimes.
When you switch the source for broadcasting, it will stop all encoders and disconnect, then initialize source and connect to the streaming servers. The disconnect/connect, as well as input initialization, is performed quickly, the rest depends on the server (e.g. it may block immediate reconnect attempt).
Quando si cambia la sorgente per la trasmissione, tutti gli encoder vengono arrestati e disconnessi, quindi la sorgente viene inizializzata e si connette ai server di streaming. La disconnessione/connessione, così come l'inizializzazione dell'input, vengono eseguite rapidamente, il resto dipende dal server (ad esempio, potrebbe bloccare immediatamente i tentativi di riconnessione).
ok Grazie
