Radio Boss Suggestion for others updates
Radio Ltu FM
I have some suggestions for you for the next updates.
1.) When a song ends in video format, have a fade out effect (that fade should only be applied to the audio in the video clip and not the video itself)
2.) Add to the video, personalized overlays (radio station logo,...), personalized lower third overlay,...
3.) There should be a special browser in the application so we can customize the sound (bass boost, voice boost,...)
I hope you will see my suggestions and they will be added.
Best regards,
Radio Ltu FM.
Thank you for the suggestions, we will be improving video support and all features that you mentioned are planned among those improvements.
I also have a suggestion for future updates, particularly regarding the accessibility interface for screen readers:
I'd like a single-key keyboard command that, while playing a track, allows you to hear the remaining time and only that.
Currently, before hearing the remaining time, you have to listen to the entire track title, which I think is unnecessary and a waste of time. Thanks.
We'll consider adding this feature, thank you.
Hola, estoy reproduciendo solo videos .mp4 pero al querer hacer escucha previa me detiene la reproduccion general alguna ayuda gracias
Hi, I'm only playing .mp4 videos, but when I try to preview them, it stops the main playback. Any help would be appreciated. Thanks
This is a limitation of the video engine in RadioBOSS, it only allows playing one video at a time.
