RadioBoss 7.2.0.0
doug.sinclair
RadioBoss 7.2.0.0
Operation of the test station is running smoothly, did notice that the logs are not working for showing the elements that have played and when.
Doug Sinclair
Web Net Radio
The Smooth Jazz Florida Radio Network
Appently there is right click option on the Log Dialog box that will engage the files that are
to be displayed. To me it was apparent that that function needed to be addressed and adjusted
to the end users preference.
Once this function was engaged the log entries are showing on the program log display.
Doug Sinclair
Web Net Radio
Smooth jazz Florida Radio Network
Yes, you can set the filters from the right-click menu. One of the ways to use them is to add a separate Logs tab in one of the work zones and set it to display errors only, this way you won't have to constantly enable/disable filters in the main Logs tab.
Beautiful RadioBoss
