RadioBOSS 7.2 [beta]
We'll check it again, but for now I'm not sure what the problem is. Maybe you changed normalization algorithm - please check in RadioBOSS Settings > General, Advanced settings. In Audio section normalze algorithm should be set to 0 to use EBU R128.
OMG
OK, that was the reason—instead of 0, I had entered -13 there.
Now I entered 0 there, and now everything works as it should, or at least the way I want it to.
Thanks for pointing that out.
I see that the Advanced Settings page is in English, even though my RadioBoss language is set to Spanish.
Will that change when the final version is released?
I just found and read this. It's a shame that you can't translate it.
They could do it, but they don't want to
I'm not entirely sure why they don't want to translate the “Advanced Options” either
But to be honest, the way the menu is organized now is already much better and easier to understand than in version 6.1.
