Put a Shuffle Button on the toolbar?
Countryguy
Hi There from Australia. I have been a Radioboss user for some years. It is a great program to use. What I would like to know is there a way to put the Shuffle Button on the Toolbar. I use this quite a bit and think it would be a useful addition. Thanks again for a good and solid radio broadcast program. Wayne from Australia.
The Shuffle button is located under the playlist along with other playback controls. However, using it is not recommended because it doesn't check for repeats. It does try to not select the same tracks too other, but it's optimized for speed, not quality.
Hi thanks for your reply. My idea with the button comes from useing SAM Broadcaster at my work at a Sydney rsdio station. When you pushed the Shuffle button it automitically shuffled the music tracks in the playlist and you could see the changes. When you use the Shuffle in Radioboss you dont know what track will play next. You can go into the program and push Control-Shift S and it mixes the tracks. I just thought a toolbar button would be more convenient than going into the menu. Thanks for great program.
