RadioBOSS Cloud 3.0 [release]
RadioBOSS Cloud 3.0
Changes
  • Track artwork is now displayed in the Overview and Media sections.
    Note: To display artwork for existing tracks, reindex your music library by clicking the Reindex Tracks button in the Media section.
  • Scheduler: added End Date/Time option
  • Scheduler: added Maximum time to wait in the queue option
  • User accounts: added configurable Home Folder for each user to restrict access to that folder only (applies to the Media section and FTP file access)
  • Improved listener reports (Listeners > Statistics)
  • Song requests: added buttons to insert requested songs into the playlist and delete requests
  • Song requests: added ability to edit widget system messages
  • Added Cut / Copy / Paste commands to the playlist editor in the Media section
  • Prelisten player in the Media section now supports seeking and displays playback position
  • Improved Logs display
  • Improved search in Media
  • HTTP notifications: added %xmldata variable to send detailed track information
  • Fixed: HTTP POST notifications were sometimes not sent correctly
  • Fixed: search ignored the Include subfolders option
  • API: added /getstats command to retrieve listener statistics
  • Other improvements and minor bug fixes
RadioBOSS Cloud 3.0.2 update
Changes
  • Improved overall system performance for playback, control panel, and widgets
  • Fixed several bugs reported after the 3.0 release
Hi, I think the latest 3.0.2 update broke the artwork system.
Since this morning, the default artwork is just black. It works fine with the tracks that have an artwork, but it displays a black artwork for any track that doesn't, even though the default artwork is set correctly
Can you please specify what artwork is broken, is it the one that's shown in the playlist/media section, or the one that is sent to listeners/artwork widget?
We're noticing this as well, the widget is now just showing a black square instead of artwork.
Yes, it appears to be failing to load the default artwork, while loading artwork for tracks that have it. We're working on a fix and an update will be released soon.
Exactly what the other user commented, a black artwork on the widget instead of the default one when it's not available for a certain song/jingle. Thanks in advance for the upcoming fix :)
RadioBOSS Cloud 3.0.3 update
Changes
  • Fixed: the default artwork was not displayed on some streaming accounts
Notes
  • If artworks are not shown properly in the Media section, or in the playlist window in Overview, please reindex your music library by clicking the Reindex Tracks button in the Media section.
I noticed that when playing a Scheduled Stream using the Network stream URL, it displays the last song play on my cloud stream instead the actual stream name although i checked the box "Use event title as broadcasting title".
Will this be fixed????
Did you specify the event title? If it's empty, it will not work.
Now Playing widget is also showing the last song played and artwork, however it is showing the length/time of Scheduled URL.
Under Playlists i can see the title track or specified event but it doesn't reflect the same on any of the multiple "Now Playing" tabs or even the widgets.
Please specify if this event is played as an Overlay event, or it's inserted into the playlist? For Overlay events, you need to enable titles in Settings > Streaming.
No it's not an overlay event. It's is a URL of one of our stations that is scheduled to Run at a specific date and time. the URL is placed in Action and Show Title is placed in Title, Use Event Title box is checked, Event is enabled and Run without waiting for current track to finish is checked. It runs but just don't display that it's running. I'm seeing the previous track or program. this only happens with URLs.
What if I'm using an external encoder in RadioBOSS Cloud like EverestCast or Fastcast4u and if that's the problem, what do you recommend I do to rectify this issue. I have remote DJs and so I use EverestCast system to create their profiles.
