problem transitioning with the ultimate version 7.2.1.8
byron
Hello, after updating to the latest version 7.2.1.8, crossfading with video files no longer works as before. My audio jingles with an end mix point used to crossfade with the video normally, but since the update, they only appear and work before an audio file, but disappear before the video, which doesn't even display the waveform like in version 7.1.14. I know the video is limited, but I managed to cut them out before and after for proper playback. Is this a bug?
Video files are not supposed to be mixed with anything, other video files, or even with audio files. We'll be improving video support to allow proper crossfading in one of the future updates.
Yes, but it works with version 7.1.1.4; the audio jingles mix in the video input but not the output, and that was already pretty good?
It works perfectly with OBS. Radioboss sends an end-of-video signal and triggers a video on OBS to cover the audio jingle, then transitions the video clips seamlessly, and at the end, it creates a clean cut.
This was actually a bug that got fixed in the latest release. Now jingle will wait when the video ends, then play.
