Order of programs
WLGO
We have a playlist that plays everyday from 5-6pm. The program pulled from the file, we want it to be in order, but when we click "in order" and Start position 1 and advance on each generation but it keeps playing track 1 over and over again. How do we fix it to play the next one?
Please provide more details on how the track is selected, do you use the Playlist Generator or it's Track List? The "advance on each generation" option exists only in the playlist generator, in which case it means you create a playlist (and it's saved) then you run this playlist. Check the Logs window to see if there are any errors.
To simply select tracks from a folder in order, if you only need a single track selected each time, it may be easier to use Track List - in the event editor, open the Wizard, it has an option to do this.
Please see how we have it set up in screenshot below. It may be more difficult to use the tracklist since some of the programs end at different times we would not know the exact time to set it to start playing.
When configured like this, it should work, that is, the current position (in the track source) is increased by +1 each time a track is selected, and after the playlist is created, position is remembered, then the next time playlist is generated, it will continue from that position.
What RadioBOSS version do you use?
