Bug next track
Tekno1 Radio
I've noticed a bug with the previous track and next track displays. When playing a playlist that was created in a single pass, everything works correctly. However, as soon as a scheduled event is activated and generates voice tracks inserted into the playlist, the previous track and next track information becomes incorrect.
Any idea what could be causing this?
Thanks!
Does it happen after a scheduled event starts? What does the event do, does it only insert a single track? The screenshot is not complete, and the Log section is not visible in full - so it's hard to tell what happened; can you please post a full screenshot?
thx for reply,
After a scheduled event, it randomly triggers voice tracks at 00, 15, 30, and 45 minutes of each hour.
It's still hard to tell why it happens - the currently playing track started at 19:10 while the log shows up to 18:59. Does it always happen after a generated playlist is loaded?
Yes, during the normal playback of the 24-hour playlist generated by Playlist Generator Pro, there is no problem. The issue only appears when voice tracks are inserted; that's when the previous and next track display becomes incorrect.
This doesn't reproduce here. What does the event do, it only inserts a single track that is a voice track?
