Playlist Generator Pro : Advanced Category Variations Directly in the Rotation Window
JeanXeb
Hello Dmitry, RadioBOSS team,
Several years ago, I had suggested two improvements for the Playlist Generator. One of them "the globalized categories" was implemented, and I want to sincerely thank you for that. It has made daily work much easier.
Today, I would like to bring back the second part of that original suggestion, because with more experience using RadioBOSS, I’m convinced it would be a major improvement.
Category Variations Directly Inside the Rotation Window​
Currently, when we want different variations of the same category (for example: different tempo levels, male/female alternation, language balance, tag boosts, etc.), we must duplicate the same category many times, even when using globalized categories.In some cases, this means creating 10, 15, or even 20 copies of the same category just to adjust small parameters.
This becomes difficult to maintain and makes the Categories screen heavier than necessary.
Proposed Improvement​
Inside the Rotation window, under each category entry, we could have the ability to:
  • Include or exclude specific tags
  • Increase or decrease tag weight
  • Adjust tempo or energy level
  • Fine‑tune alternation rules (Male/Female, languages, etc.)
  • Boost or reduce specific attributes (e.g., +10 weight for “Boost” tag)
All of this without having to create multiple category duplicates.
Example​
Instead of creating:
  • Reggaeton 1 (high energy, female)
  • Reggaeton 2 (high energy, male)
  • Reggaeton 3 (lower energy, boost tag +10)
  • Reggaeton 4 …
  • Reggaeton 5 …
  • etc.
We would have one single “Reggaeton” category, and inside the Rotation window we could define:
  • Reggaeton > Rotation 1 → very dynamic, female
  • Reggaeton > Rotation 2 → very dynamic, male
  • Reggaeton > Rotation 3 → less dynamic, +10 weight for “Boost” tag
  • Reggaeton > Rotation 4 → different alternation
  • etc.
This would give us much more precise control over the hourly rotation while keeping the category list clean and simple.
  • No more dozens of duplicated categories
  • Faster rotation design
  • More flexibility for programmers
  • More accurate and dynamic scheduling
  • Perfect for stations with many formats or sub‑genres
Thank you again for your continued work on RadioBOSS — this feature would be a powerful addition for many users.
Thank you for the suggestion, but I'm not sure it'll work.
This is a source of many conflicts and complications. Each category has its own set of settings (as it is now), and then some of them can be overridden in the rotation. For instance, you edit a category and change some filters - you expect this change to work. But you forget/don't know that this filter is overridden somewhere in the rotation (and maybe in a different template, if you edit a global category), so the change doesn't have an expected effect. Things will get out of control quickly, and would be hard to manage also - now that there's no single "source of truth" for a category.
Generally, there are only a very few adjustments: a "Boost" tag that promotes tracks with that tag, or a specific restriction to ensure that the schedule moves a bit during the hour and doesn't get stuck. Or, an "uptempo" or "downtempo" tag so that the program has an evolving structure throughout the evening with shifts in tempo.
Right now, it’s actually already complicated because we've had to duplicate categories sometimes up to 10 times to achieve this result.
Indeed, if I change the tags or other information in the example given for Reggaeton, I would have to change it across all 10 subcategories that were created.
I understand your point of view.
In your case, maybe, but it can be used very differently by others. And still it means global categories are no so global anymore, as templates can override filters. I honestly think this feature will bring more problems that it would solve. Imaging how many "bug reports" we'll receive about "playlist generator ignores filters" because of this :)
Hello Djsoft,
I completely understand your concerns regarding the potential for confusion and the importance of keeping a "single source of truth." It makes perfect sense from a support and development perspective.
However, we are still facing some real-world broadcasting constraints, and I would love to hear your recommended approach on how to handle them efficiently with the current system. For instance:
  • Broadcasting regulations: How can we easily meet strict national quotas, such as ensuring exactly 20% of Spanish music across an entire day's programming?
  • Vocal alternation: How can we properly alternate between a male voice, a female voice, and a band/group within the same hour?
  • Energy flow: How can we smoothly increase or decrease the tempo throughout a playlist to create an evolving structure?
Currently, these are scenarios for which we don't really have a viable answer without endlessly duplicating categories.
What would be your best practice or solution to achieve this without cluttering the category list?
Thank you again for your time and guidance!
You can use different categoriesin a rotation, e.g.:
1. Spanish category
2..5. Some other category
This way, the playlist will contain 20% (1/5) Spanish tracks.
This is a general idea, you can have a different setup (like 2 Spanish, 8 others) and mix in station ids and other items.
This can also be achieved by using the categories and proper filters. The number of categories will increase of course, so you'll have Spanish-Male, Spanish-Female, etc.
If it doesn't have to happen within one hour, you can create different rotations for different parts of the day.
Without trying to catch you out, it is quite clear here that a significant number of categories needs to be created, and there seems to be no other solution to achieve the results requested by our most demanding clients. This is by no means a criticism; I am simply trying to understand and be constructive because, in some cases for example, we have very strict broadcasting constraints.
For instance, wouldn't it be possible to define this in the Tracks tab > Select tracks by Category (as shown in screenshot 1).
This would apply the initial filtering for the base 'Music' category, and then allow us to add sub-filters, as shown in screenshot 2. If, in screenshot 2, we can once again apply a filter such as 'Language', for example then it becomes easy to create 'Spanish Music' and manage all the music from the initial base music category, and so on indefinitely.
The result would be that Screenshots 3 and 4 are displayed as shown here in the same window to create a subcategory.
This is an interesting idea, do you think such a filter should apply to all categories in the source? Or there should be multiple additional filters for each category separately? I think one filter for all categories in a source is pretty workable solution. Question is what to do with filters already present in the categories themselves.
For our use on national terrestrial media, there are programming requirements and government restrictions that mean the most efficient solution—integrating what already exists—would be to have:
The main category, for example (Music), with all current restriction filters (without modifying anything at this level). This essentially forms the rotation base for future sub-categories, which prevents us from having to re-edit this entire layer simply to add a filter like "Spanish."
Then, this is where it gets interesting: we reuse this "Music" category instead of "Tracks" in the playlist generator by "Category". Here, there is no need to add multiple categories; just putting "Music" is already very good.
Next, we can apply additional filters. Generally, the bulk of the filters are already in (Music); the idea here is to apply light additional filtering (selecting a language + one or two exclusion or inclusion tags + BPM + YEARS), which will already be quite good. That being said, "he who can do more can do less"—if you could bring back all the tabs (Filters, Priority, No-repeat, Constraints), that would be a bonus.
The idea isn't for the software to spend 4 hours generating a one-hour playlist either, and it won't be efficient for us if it involves generating sub-categories of sub-categories...
On the other hand, it would be highly beneficial if the software could cache the (Music) Category when generating the playlists, in order to easily generate the sub-categories afterward. If the software has to re-calculate the entire path for each sub-category, our servers will struggle during playlist generation. We wouldn't want your recent database generation optimization work to be compromised by this new approach.
But please understand that with this addition, our radio stations could be managed with a level of precision that we simply cannot achieve today. We are truly talking about a major breakthrough for us as professional radio broadcasters.
I see, this sounds interesting - I added this to the features list to consider for the next versions.
Thank you and Dmitry for listening.This is what makes RadioBOSS appeal to more and more people !
A well-adapted product is the key to success.
I hope your team will consider this solution for a future version!
best regard !
