Very Rarely, Two Tracks Play Simultaneously
easace
During a track transition, when the next track starts playing, it sometimes gets skipped almost immediately and the following track starts instead. When this happens, the audio from both tracks continues playing simultaneously until the tracks finish.
I have experienced this issue a few times, but it is extremely rare, occurring only once or twice a month. I also remember encountering the same issue in a previous version.
Interestingly, I experienced it twice with the same track, but it also happened again with a different track combination. However, I cannot reproduce the problem by arranging and playing the same sequence of tracks again, so I have not been able to determine exactly what causes it.
The video shows a recording of the stream at the time the issue occurred, including both the audio and the album artwork. You can see that the second album cover changes very quickly and the third album cover appears. At that point, the track associated with the second album cover is still playing, while the track associated with the third album cover also starts playing. As a result, the audio from both tracks can be heard simultaneously.
The issue appears to be related to the transition/track switching process, but because it occurs so rarely and cannot be reproduced consistently, I am unable to identify the exact cause.
You should check the crossfade settings, the Trigger Mix option, and also if you use the Segue Editor, and what parameters are set for the playing track (Mix), and for the following track (Mix Start) in Track Tool - because mix point is calculated based on current and next track's settings.
It may be a good idea to turn off Trigger Mix at in the crossfade settings, to avoid dynamic mix point detection on air, and process tracks instead, in advance, to determine and set all playback parameters: https://manual.djsoft.net/radioboss/en/process-tracks.htm
I don't use the Segue Editor; I only play tracks from the queue. So why don't the same settings always produce the same result? If this is a settings-related issue, shouldn't the same track list always play in exactly the same way?
Yes, the mix point position calculation is fully deterministic, that is, for the same input it's always the same result. But the input may vary because it uses the current track and the next track for calculation, and if voice track is involved, the next after next track as well.
So the result depends not only what track is played, but what tracks are after it in the playlist.
Also what RadioBOSS version do you use?
That's exactly why I mentioned it. When I arrange the same three tracks in the same order, the issue does not happen again. This is a very rare occurrence.
We had a similar report from another user, couple of months ago, and did extensive check of this bug - it was not possible to reproduce it here, and relevant code review also did not find anything out of order. There's no point in checking it again as mix point calculation did not change in the past couple of updates, so this bug will stay as "reported but not reproduced state".
What you can do is prepare tracks and turn off Trigger Mix as described in the previous message in this topic.
I’m not sure if this is the same issue you’re describing, but in my case, on very rare occasions, I’ve had two tracks playing at the same time.
What I’ve noticed is that this seems to happen when the previous track has a very low volume level. In those cases, RadioBOSS may start the next track while the previous one is still playing.
Low volume level and "Trigger mix at" enabled means that Mix point may be detected in a middle, or any other point of a track.
