Additional separation rules
Altec
Hi Dmitriy,
I wanted to create few rules to separate tracks with tags but i don't understand how it works, it seems there is a bug because we can create only one rule, but if i create a rule and i set 10 minutes separation for TAGA TAGB TAGC it means that a track with one of these tracks will be separated or it seems you need to have a track with all of 3 trags ?
Best regards
Altec
The "Do not repeat Tags for 0 minutes" rule will do nothing because the period is 0 minutes.
Any of the tags must present in a music track for the rule to apply.
For example, if a rule defines "Tag1, Tag2" and a music track contains only Tag1, then repeat rule will be checked for Tag1, when it was used last, and Tag2 is ignored. If a track contains both tags, it will check against the most recent tag that was seen, and will not allow a track if either of the tags were used within the repeat period.
It Was just for the example i know !
The problem is we can create only one rule for tags ? is it normal ? When you click on "+" you can create another but it doesn't appear.
Ok that's not very clear you must update the notice :').
This comes from the time before Tag rules can be added there - this was to avoid having different rules for the same field. For Tags, in the next version it'll allow creating several rules.
It'll be mentioned in the manual or somewhere in the UI to make it clear.
For this one, it could be very, very useful to be able to select a specific genre for example "Christmas" or "Latin" because in my case firstly I don't have many genres on my radio, and it could stuck the playlist generator, and in another hand all my metadata are not fully complete, many songs have no genres.
Best regards
Noted for the future versions, thank you for the suggestion.
Thank you, Dmitry, I have the same idea for language example do not repeat language "Spanish" period "15 minutes" because in my case i have 95% English music, so this parameter is useless if you are not able to choose what language.
Ty
Altec
