Output to decoders
HMMMM
I am noticing some problems with mic control when I push check box to set mic to 'output to decoders only' only to decoders it just plays silence is there a fix for this can anyone assist?
When this option is enabled, it will only play mic on the streaming encoders, and you won't hear it locally. If you don't hear it on the stream either, then try disabling this option and check if the MIC works at all - with the option disabled, when you press MIC button, you should hear yourself. Also check the Logs window to see if there are any errors regarding mics or inputs.
