Pitch playout
Riddle
Hi,
I would like to request a '% speed/pitch up/down' option just like Stationplaylist.
This can be just a slider to pitch up playout of the playlist (except livestreams, etc, so only music) or a check within the 'file types' menu
RadioBOSS used to have pitch and playback speed controls 10 or so years ago. This was removed, and it's extremely rare when one needs those features. I'm sorry, but I don't think we'll be adding such a feature, it seems very few people need it.
I'd pay extra for this feature! $49
I'd appreciate it a lot.
Just curious as to why people want pitch control?
Yes, me too. RadioBOSS used to have pitch control in one of the earliest versions, more then ten years ago. When we have removed it, no one noticed it and never asked about it ever since. Why all of a sudden such an interest in it (we've also received a dozen of support tickets about it from different people) - is a mystery :)
If you can possibly put the pitch control from 10 years ago in and release it as a tester I'd try it.
The problem here is that the demand for this is questionable. No one ever asked about this until the past few days.
How much pitch is being added to make it sound brighter?
It depends if your playing your music at 102.7% your gonna make your audio pitch be 0.46 semitones. If your gonna play your music 102.3% as iHeartRadio stations do 103.5 KTU FM, it'll be 0.39 semitones.
If you just raise pitch it'll start to sound echo-y and weird on some songs. If you do it the correct way by making the audio faster and pitch it'll be done "right".
Sample of "done right"
This feature is currently under consideration but not assigned to any version at this moment. I can't tell if we'll be adding this.
Ich kann mir nur Vorstellen warum sich die Leute so einen Unsinn wünschen ..... Sie kommen wahrscheinlich vom " Sam Broadcast " und mögen diese Quietscher ei wie es dort möglich ist .... na jeder Versaut sich seine Sendung und Musik halt selber 🤭.
Also jetzt mal ernsthaft das braucht kein Mensch den bedenke das du das auf die gesamte Playliste übertragen würdest aber auch im Einzelnen auch auf das Mic und nehmen wir mal deinen Wunsch dieses auf die Playliste anwenden zu wollen , da klingt dann jedes Lied ander aber eines haben dann alle Lieder gemeinsam .... sie klingen schief und schräg aber sicherlich abartig ....!
Liebe Leute wenn ihr eure Audio Daten im Klang ändern od. Anpassen wollt macht dieses immer nur auf der jeweilige Einzelnen Datei und noch eine Anmerkung wenn die Datei schon auf deiner Festplatte scheußlich ist solltest du da schon mal Anfangen mit der Korrektur und nicht erst im Radio Boss 😉.
Noch ein Schlusswort : Sam Broadcast ist " 2019 " vom Gericht Liquidiert worden , der Sam Broadcast wird nur noch durch einen Ehemaligen Geschäftsfreund erhalten aber eben auch nicht weiter Entwickelt , zudem kommt auch noch dazu das Sam Broadcast auf seinem Grundgerüst aus dem Jahre " 1998 " auch noch heute Arbeitet alles andere ist nur Makulatur eben weil es nie eine Weiterentwicklung gegeben hat , also streicht doch endlich mal diese Ding aus eurem Gedächtnis !
Google Übersetzer :
I can only imagine why people would want such nonsense... They probably come from "SAM Broadcaster" and like those squeaky, high-pitched effects you can get there... well, I guess everyone ruins their own show and music in their own way 🤭.
But seriously, nobody needs this. Just consider that you’d be applying it to the entire playlist—and to the mic input as well. Let's say you apply this effect to your playlist: every song will sound... well, they’ll all have one thing in common... they’ll sound off-key and distorted—absolutely awful, for sure!
Folks, if you want to alter or adjust the sound of your audio files, always do it on the individual file itself—and do it while the file is still on your hard drive. It’s a terrible idea to start making corrections inside RadioBOSS instead of doing it beforehand 😉.
One final point: SAM Broadcaster was liquidated by court order back in 2019. It’s only being kept alive by a former business associate, but there is no further development. On top of that, it still runs on a core framework from 1998; everything else is just window dressing because the software never actually evolved. So, please—just get that thing out of your heads once and for all!
This is why "Pitch", as well as "Tempo" were removed from RadioBOSS some 15+ years ago, as those feature did not have real practical use. It makes sense to add those settings per-track using Track Tool though, and this is a feature we consider adding.
All major automation packs have this functionality, FM radio stations use it, for whatever purpose, but only on the Music files.
