64-bit builds
Added RadioCaster 64-bit.
Limitations: RadioCaster x64 is unable to use any Winamp DSP plugins (they are all 32-bit) and also VST plugins are not supported.
Added RadioBOSS 64-bit.
Limitations: RadioBOSS x64 is unable to use any Winamp DSP plugins (they are all 32-bit) and also VST plugins are not supported.
Load my profile and the application is blank (It does not even generate a bugreport). This error was sent by notifications (via telegram)
Access violation at address 0000000000ECEC6C in module 'radioboss.exe'. Read of address 0000000000000178. (Profile: Music One Radio, instance: C:\Program Files\RadioBOSS\radioboss.exe)
Did it start normally after installed, and crashed after you have loaded your profile from a backup?
i use JB Broadcast which seems to be a VST, and it works fine
This is really odd because VST bridge is completely turned off in the 64-bit build :)
Please open the settings folder (C:\Users\username\AppData\Roaming\djsoft.net\RadioBOSS_nn) and send the bugreport_*.txt files from there, maybe they will help to understand what's going on.
It only supports 32 bit and we need to create another VST bridge, this will happen at some point in the future.
I was just wondering when you plan to implement the x64 bit version, and here it is .... it's a big step forward and it definitely has its advantages. I hope for relatively fast support for the x64-bit VST section ....
VST can be delayed a bit because we won't be porting the current implementation (it has lots of problems) but instead create a new one for 64 bit.
The latest RadioBOSS 64-bit release (6.0.5) now supports VST plugins using the same technology until we create a new VST bridge. Requires 64-bit version of the plugins.
Updating to the latest version
Database error: [FireDAC][Phys][MySQL]-314. Cannot load vendor library [libmysql.dll, libmariadb or libmysqld.dll]. libmysql.dll has unsupported architecture [x86]. Required [x64]. No se puede encontrar el módulo especificado Hint: check it is in the PATH or application EXE directories, and has x64 bitness.. See log for details (double click to open log).
The included server does not work with flac. (in version 64)
Also when trying to exit the program crashed. (did not issue any report)
