lughsan
Hello Dimitry, how are you?
I have been testing the version you sent me for windows xp, and the latest version.
Both versions have the following problems:
Does not allow inserting the time:
Thought of working in manual mode, it would help a lot to work live, insert time, also temperature.
Imagine that the broadcaster who is live, giving a single click broadcasts the time, temperature and advertising, all together and in a simple way.
solution:
program a playlist with the indicator and the time, seconds before the broadcast of the advertising block example:
Playlist.
08:59:57
1 - The Radio tells you the time.
2 - hour.(it's 9:00 in the morning.)
advertising block.
09:00
3 - Advertising 1.
4 - Advertising 2.
3 - Advertising 3.
4 - Advertising 4.
Priority limit to sort ads:
this would help us add the ads in order.
solution:
We have priorities from 1 to 9. Allow ordering the ads according to the selected priority example:
that each priority allows inserting ads with suborders, according to the ads inserted.
I schedule the first ad in priority 1.
I schedule the second ad in priority 1a.
I schedule the third ad in priority 1b.
I program the fourth announcement in priority 1c.
in this way successively......
The idea is to do it automatically.
It does not allow to give it a different order according to the schedule:
Give an order according to the selected time 09:00, 10:00, etc.
solution:
which allows us to specify the order in each selected block.
Advertising block. (normal)
09:00
Advertising 1. (priority 1)
Advertising 2. (priority 2)
Advertising 3. (priority 3)
Advertising 4. (priority 4)
09:30
Advertising 3. (priority 1)
Advertising 4. (priority 2)
Advertising 2. (priority 3)
Advertising 1. (priority 4)
10:00
Advertising 4. (priority 1)
Advertising 1. (priority 2)
Advertising 2. (priority 4)
Advertising block. (automatic)
09:00
Advertising 2. (priority 1a)
Advertising 3. (priority 1b)
Advertising 4. (priority 1c)
09:30
Advertising 4. (priority 1a)
Advertising 2. (priority 1b)
Advertising 1. (priority 1c)
10:00
Advertising 1. (priority 1a)
Advertising 2. (priority 1c)
I also ask you to answer my question.
I can't activate DTMF tones
Greetings, Dimitri.
solution:
Playlist.
08:59:57
advertising block.
09:00
3 - Advertising 1.
4 - Advertising 2.
3 - Advertising 3.
4 - Advertising 4.
solution:
solution:
09:00
09:30
10:00
09:00
09:30
10:00
Greetings, Dimitri.
