Auto amp
192khz
Can someone explain to me what the controls on autoamp do?
Ex. Target level, silence level, change amount, and change delay.
Thank you.
Target level should be set at 0dB (and if you need to modify output level, please use the Gain slider in the main window). v
Silence level - if the level is below this threshold, it won't amplify it.
Change amount - the amount of how much the level is changed in one go
Rate - how often level changes are made.
Please note that normalizing tracks yields a better result if you want to make all music play at the same level: https://manual.djsoft.net/radioboss/en/normalizing-tracks.htm
