Auto DJ's and Shuffule
southsound
Does Radioboss have a facility or plans for a way of shuffling the playlist automatically at the end of the list, and does it, or have plans for a auto DJ, to make the radio station sound slicker, this is because it waits for the songs to end before playing the next item?
You can use Shuffle mode, so there will be no need to shuffle playlist itself.
What AutoDJ should do? For now, radioboss can mix tracks automatically (fade in., fwade out, mix settings) so it should sound pretty good.
there is a shuffle button that does it the once unless someone is about to do it again,
is there a way to do it automaticlly.
thanks
The Shuffle mode will stay on until someone turn it off. I don't tell you about the menu option Playlist->Shuffle. Please see picture attached, the "SHFL" button turns Shuffle mode on/off.
Is there away of getting songs to play from a catagory (example radio boss to be programed to pick songs from the A catagory, B catoagory, C catagory) and then mix it up by picking another songs from B then A then C, So it can play different era of songs.
Soon there'll be a new program, called Playlist Generator Pro, which does exactly what you need. Release in September I think.
