Bug HELP!!!
djwolf
Whenever I load up another profile, even though I have saved the database it says there's nothing in the library off to the side. I just purchased RB, and it was working fine until I updated to 4.7.4. Please Help!
Where are you seeing this message?
For search feature on the left it uses the music library file specified in the Settings->General. Make sure it's the same file where you've saved the library (it should be the same by default if you didn't change it).
No, there just not there. There's no tracks in the viewer on the left, but in the music library window, there are tracks.
Tracks will appear when you start searching - enter something in the "Find:" field.
I have nothing in the search field and there's nothing there. This happened when I switched Profiles.
Could you please make a screenshot? The latest update doesn't change anything in Music Library or Search feature...
Alright, I can't upload a video. Here's a pic.
Ahh... I'm sorry, it looks like there's a bug. After profile reload search feature stops working.
Good news here: the bug was fixed!
RB 4.7.4.1: http://dl2.djsoft.net/radioboss_setup_4.7.4.1.exe
