Playlist times do not match
jonm
I'm hoping I can get some help with this. When I create a playlist on one of our computers the times do not match up when I open it in our master computer. I have synced all of the databases using MySQL and that is working fine but for some reason, the time is always off if I open a playlist that was created in one of our other computers. Hope this makes sense and I appreciate any help I can get.
Hi. Same thing happened to me, then I discovered that the crossfades, mixing points, fading and overlapping... was the issue because they are not same on the 2 computers. I can't remember exactly which one was the problem. Check and see if this is the case.
Thank you so much!! That was the problem.
