Can anyone give me advice for addition rules in Playlist generator
tomimatko
Can anyone give me advice which is the best setting for addition priority rules in Playlist generator to broadcast all songs equally often.
If you want equality, then you should notn use priorities. Priorities are used when you want certain songs to play more or less often - a task opposed to equality.
I meant these rules. Or should I leave that blank too?
You only need to add rules if you want certain tracks to appear more or less often in the playlist. You can read more about the priorities here: https://manual.djsoft.net/radioboss/en/plgen-cat3.htm
