Command "connect" "disconnect"
haeiser
Hi all,
to connect to the server via the command "connect" and play afterwords the active playlist works fine.
to disconnect after by the command "disconnect" there will be no disconnection from the server.
Do you know the problem? and / or have you a workaround?
Thankx
Please make sure there's no typo in the disconnect command. And also check the messages in the log, are there any errors?
