Radio-Albena
I'm occasionally getting the following error in RadioBOSS:
Remote Control exception: Error in parsing command.
The error occurs intermittently, and so far I haven't been able to identify what triggers it.
I'm using RadioBOSS 7.2.2.0 on Windows.
I also use the RadioBOSS remote control/API functionality for external integrations and monitoring.
Could you please clarify:
Any advice on how to identify the cause would be greatly appreciated.
Thank you!
- What exactly does this error message indicate?
- Can it be triggered by an incorrectly formatted or unsupported API command?
- Is there a way to identify which command or remote connection caused the error?
- Is there any additional logging or debugging option that would help track down the source?
Thank you!
